LCD&pic18F452 setup
Silver
LCD&pic18F452 setup
PostPosted: Tue Jun 14, 2005 2:02 am     Reply with quote
Can you help me to set up my pic18F452 in order to write on LCD display?My electric connections are:
LCD Pic18F452
D0 D0
D1 D1
D2 D2
D3 D3
RS D4
RW D5
En A5
How can I modify the pin map structure of LCD.C to match this configuration?
Thank you
PostPosted: Tue Jun 14, 2005 4:26 am     Reply with quote
LCD PIC18F452
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
with this pin assignment u can use the posted code by chingB at http://ccsinfo.com/forum/viewtopic.php?t=23234&sid=53884f7160ba0e1a4696d801fbce3906
PostPosted: Tue Jun 14, 2005 2:11 pm     Reply with quote
display ? My electric connections are:
LCD Pic18F452
D0 D0
D1 D1
D2 D2
D3 D3
RS D4
RW D5
En A5
To modify Mark's LCD driver for your pin map, you need to make
the changes shown below. Here is the link to Mark's driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=20182
You need to use the following lcd_pin_map structure:
struct lcd_pin_map
  int unusedA0_A4 : 5;  // Pins A0-A4 are not used
  BOOLEAN enable  : 1;  // Pin A5 = LCD Enable
  int unusedA6_A7 : 2;  // Pins A6,A7 are not used
  int unusedB;          // Port B is not used
  int unusedC;          // Port C is not used
  int     data : 4;     // Pins D0-D3 = LCD Data (LCD pins DB4-DB7)
  BOOLEAN   rs : 1;     // Pin D4 = LCD rs
  BOOLEAN   rw : 1;     // Pin D5 = LCD rw
  int unusedD  : 2;     // Pins D6,D7 are not used
} lcd;
The TRIS map must also be changed to the following:
struct lcd_tris_map
int data    : 4;       // Pins D0-D3 = LCD data (LCD pins DB4-DB7)
int unusedD : 2;       // Pins D6-D7 are not used
} lcdtris;
The set_tris_lcd() macro must be changed to this:
#define set_tris_lcd(x) lcdtris.data = (x); \
                        lcdtris.rs = 0; \
                        lcdtris.rw = 0; \
                        lcdtris.enable = 0;
Important Note:
When you operate the LCD in 4-bit data bus mode, it's the upper 4 bits
of the LCD data bus that are used -- pins DB4 to DB7. So you must
connect the LCD data pins to the PIC as follows:
LCD pin     PIC pin
DB4           D0
DB5           D1
DB6           D2
DB7           D3
Silver
PostPosted: Wed Jun 15, 2005 10:17 am     Reply with quote
Thank you for the code!!! Now my lcd works properly
