CCS and TinyPIC Bootloader
thb
PostPosted: Tue Jun 07, 2005 10:02 am     Reply with quote
I tried to use the TinyPIC Bootloader together with the CCS compiler, but it doesn't work. I can download hex files to the pic but they won't start up. Until I try a lot of things, maybe someone of you knows which code lines I have to add to my CCS programs in order to work with the TinyPIC.
For assembler an example is given on the homepage but I don't know how to convert it to c.
org 0
;clrf STATUS
clrf PCLATH
goto Main
or
org 0
;clrf STATUS
pagesel Main
goto Main
By the way, if it's important, I'm using a 16F873 and 16F877
Thanks for your help
Thomas
PostPosted: Tue Jun 07, 2005 2:45 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=22523
thb
they talk about PIC18s
PostPosted: Fri Jun 10, 2005 5:19 pm     Reply with quote
Hi, thanks for the link, but this does not help me so much. It sais more or less that nothing has to be done to adjust CCS programs for TinyPIC and maybe that's true for the PIC18 but I tried it on my PIC16F873 and the bootloader works good but my program still does not start.
If somebode has some advice, thanks a lot!
Thomas
thb
PostPosted: Fri Jun 10, 2005 5:23 pm     Reply with quote
By the way, I forgot, I don't use interrupts or something else special, it's just a simple program (until now).
PostPosted: Fri Jun 10, 2005 5:48 pm     Reply with quote
I tried to assemble the ASM source code for the Tinybootloader that is
programmed into the PIC. It just gets tons of errors in MPLAB 7.10.
This is with the MPASM assembler. It doesn't like the Radix statement.
Then it doesn't find an END. If those errors are fixed, it gets more
errors.
OK. I'm not spending any more time on "tiny" bootloader.
It's a time sink.
I suggest getting another bootloader or dump the bootloader entirely
and go to ICD2. That's what I've done. I've installed ICD2 header
connectors on all my test boards. It's much better.
future
PostPosted: Fri Jun 10, 2005 9:06 pm     Reply with quote
I am using the tiny bootloader for a long time, never had problems.
I use a 18f452 and the simple JDM programmer to install the BL.
PostPosted: Fri Jun 10, 2005 11:52 pm     Reply with quote
Ououooooo....
For me, Tiny Bootloader is the best one I´ve ever used.
I´m using on every 18FXXXX based project, and never had compiler errors. Do you have the 3 files needed for compiling it ?
Mark.-
thb
assembling the tinypic was no problem
PostPosted: Sat Jun 11, 2005 5:53 am     Reply with quote
assembling the tiny pic loader was no problem, just change the oscillator speed and pic type and then use mpasmwin.exe to assemble it. However the path of the files must not have more than 63 characters.
However I don't get programs run on 16F pics and here just seem to be people who use it with the PIC18s ;-)
Thomas
soba
tiny bootloader
PostPosted: Mon Sep 26, 2005 4:39 am     Reply with quote
what do I need to add my C code and here:
ORG first_address ;space to deposit first 4 instr. of usr prog.
nop
nop
nop
nop
to let tiny work?
I'm using PIC18F.asm code for PIC18F8720. PC software can find the PIC and can load the code over serial port but chip does not work.
should I add #build directives to my code for main and interrupt vectors?
JamesW
PostPosted: Mon Sep 26, 2005 2:30 pm     Reply with quote
I've added nothing to the ccs generated code at all, and it loads fine.
The tiny code compiled fine for a 18F4525 after a couple of minor tweaks to the assembler. I didn't changed the code that the readme suggests, I compiled one of the other files as there were less errors.
Certainly I can alter the processor, baud rate and clock frequency without a problem.
I use Picdownloader for the 16F877 family, with a bit of semi-home grown assembly boot code that is a lot smaller than the given bootloader. I
If you want, I'll look it out for you
James
hector74
Tiny bootloader for 18f4525?
PostPosted: Thu Nov 17, 2005 1:21 pm     Reply with quote
hi James!
I am really interested on using Tiny bootloader with my 18F4525. Could you help me? In Tiny's web page he sais that some modifications must be done in order to Bootloader works properly for 18F4525, ¿is it right? ¿what modifications? ¿what must i do?
thanks in advance!
rAfA
najim
Tiny bootloader and 18F4525
PostPosted: Tue Jan 10, 2006 1:01 pm     Reply with quote
Hi Hector74,
Did u find what kind of modifications we have to do in order to make tiny bootloader work properly?
i ve been trying all day long without sucess... do u have some information?
thks.
Najim.
Najim
Answer to myself :lol:
PostPosted: Wed Jan 11, 2006 5:47 am     Reply with quote
Hey guys I found the solution to make tinybootloader work with the pic 18F4525...
Actually it works without any modification :P The thing is that the watch dog timer has to be disabled in orther to not reset the pic when the bootloader is working...
Hope it will help someone.
Najim.
cjusto
PostPosted: Tue Aug 01, 2006 7:04 am     Reply with quote
hey. i tried to use tiny with 18f4525.
i picked the file tinybld18F.asm file. i changed the pic model, the xtal and baud rate.
i program the pic using MPlab.
after that when i put the pic in my board, tiny software can't find the pic. and i am sure the rs232 is working well.
i have the
NOWDT,
fuse in my code.
what can i do to make this work???
