93c46 initialising
ice*
93c46 initialising
PostPosted: Wed Jun 08, 2005 6:16 am     Reply with quote
Im having this weird problem while interfacing with a
93C46C EEPROM....
whenevr i initialse the EEProm,by including the line " init_ext_eeprom()" ,the Do While loop containing the
"Read or Write" sentence,repeats itself three times..
If i comment out the line " init_ext_eeprom()",
the Do..While loop executes as it's supposed to..
I know the " init_ext_eeprom()" is executing well,because i monitored it using printf statements..
any help will be appreciated
Thankyou
treitmey
PostPosted: Wed Jun 08, 2005 9:10 am     Reply with quote
Different chips work different ways. Who's chip are you using? Is it in 8 or 16 bit mode. I think the drivers are only for 8 bit. Also can you post a small complete program. and let us know the compiler version. In general I use these for config of a FTDI chip in 16 bit mode... but I know a little about them.
ice
PostPosted: Thu Jun 09, 2005 2:25 am     Reply with quote
Im using Microchip's EEProm..in the 8 bit mode meaning ive to tie it down to Vdd
Im using the CCS 9356spi.c example as a template:
i changed the driver file from 9356spi.c to 9346.c
#include <input.c>
#include <9346.c>
No other changes were made
**ice**
Machinegrid.com :: Robots at Work!!
treitmey
PostPosted: Thu Jun 09, 2005 10:49 am     Reply with quote
That sounds right to me. I'm sorry I'm of no help,...
PostPosted: Thu Jun 09, 2005 4:18 pm     Reply with quote
1. What PIC are you using ?
2. What PIC pins are you using for your RS232 ?
2. What PIC pins are you using for the EEPROM ?
3. Post your #fuses, #use delay(), and #use rs232() statements.
ice
PostPosted: Thu Jun 09, 2005 10:52 pm     Reply with quote
treitmey,
Thanks for trying to help.
PCM programmer,
These are the pic details
pic16f876a
Hardware UART,pins 17 and 18..i use a bootloader from microchip c.
The uart works fine because ive used it for debugging my other projects
3. What PIC pins are you using for the EEPROM ?
portC
i made changes in the 9346 driver file
#define EEPROM_SELECT PIN_C7
#define EEPROM_CLK PIN_C6
#define EEPROM_DI PIN_C5
#define EEPROM_DO PIN_C4
#use delay (clock=4000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,stream=rxn ) // Set up TX RX pins
Regards.
**ice**
PostPosted: Thu Jun 09, 2005 11:17 pm     Reply with quote
portC
You're already using pins C6 and C7 for the RS232.
You should change your pin assignments in the list
above, so that you don't use C6 and C7 for the EEPROM.
Then re-wire your board, and test it with the new code.
ice
Ahhhhhhhh!!
PostPosted: Fri Jun 10, 2005 12:34 am     Reply with quote
Ahhhhhhhhhhhhh!!!!! goddamit!!
i never even noticed it ,not even a teeny tiny bit...jst skipped my mind that the serial pins are being used[they run at the bottom of the board]....
uhhhh!.... anyway i love doing this...learnt something....to remember this step during debugging..
Thanks PCM Prog,its working now : )
**ice**
rnielsen
PostPosted: Fri Jun 10, 2005 10:13 am     Reply with quote
Interesting thing though, in a few months, down the road, you'll be doing something similar and start having the same problem and then start thinking to yourself "this seems sooooo familiar but I can't remember what the crap I did to make it work". Twisted Evil
I can't say that I've EVER done anything like that though. Wink
