elmar44
How can i use two LCDs at one time (change driver) ?? |
Posted: Tue Jun 07, 2005 5:34 am |
Hello erverybody !
I'am a new C programmer...
...and my first project starts with a problem:
a power generator with two LC-Displays !
So - how can i tell the driver to use LCD #1 for message 1,2,3
and use LCD #2 for message 4,5,6 and so on..
The Displays are wired in parallel - only the enable pin is seperated
to differend port pins.
The used Controller is a : PIC18F6720
The hardware connection is:
PORT D :
D.0 enable LCD#1 (this is default for the driver)
D.1 rs
D.2 rw
D.3 enable LCD#2 ( normaly not used by the driver )
D.4 data 4
D.5 data 5
D.6 data 6
D.7 data 7 data for the LC-Display
I can manualy change the struct assignment to get access to LCD#1
or to LCD#2 ....but this should be possible by the program.
Please Help !
Elmar |
Posted: Tue Jun 07, 2005 3:05 pm |
Here's a page that discusses using two LCDs.
I have no idea if it works -- I'm just providing the link.
Scroll about half-way down the page to see the schematic
and code (in basic).
http://www.picbasic.co.uk/forum/showthread.php?t=626 |
treitmey
Posted: Tue Jun 07, 2005 4:11 pm |
It seems as easy as enable, print, disable.
Code: | #include <18F452.H>
#CASE
#USE DELAY(CLOCK=16000000)
#FUSES HS,NOWDT,NOPROTECT,NOLVP,NOWDT,WDT128,NOOSCSEN,NOBROWNOUT,NOPUT,NOSTVREN
#DEFINE VER_MAJOR 1
#DEFINE VER_MINOR 01
#USE RS232(BAUD=19200,XMIT=PIN_E0,RCV=PIN_E1,INVERT,STREAM=DEBUG)
#ZERO_RAM
#include <stdio.h>
#include <stdlib.h>
#include "C:\ccs\Projects\Sample code\LCD_PICDEM2.C"
#define LCD1 PIN_D0
#define LCD2 PIN_D3
//======================= MAIN ============================//
fprintf(DEBUG,"STARTING DS12887 Test.\n\r");
fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
output_high(LCD1);
lcd_init();
output_low(LCD1);
output_high(LCD1);
printf(lcd_putc,"Hello world\n");
output_low(LCD1);
do{
}while(TRUE);
What is the struct your talking about? Without some code its hard to help you. |
sags_v
Joined: 12 Feb 2006 Posts: 1 Location: Queretaro, Mexico
ds12887 question!! |
Posted: Sun Feb 12, 2006 1:30 pm |
Hello, Intente to use your code for the driver of the RTC ds12887, but he says " lithium battery dead " to all my DS12887, I do not believe that all of them the battery exhausts, since it had never used them and scarcely a few weeks ago came to me.
Really not that to do to make my application work, I Am using a pic18f458, verify the directions of the ports and the same message keeps on appearing, also all the earnings that I give him for the RS232, he reads them immediately later as 0
Some suggestion?
sorry my bad english!! ;) |
