Read external 10-bit ADC
densimitre
PostPosted: Tue Jun 07, 2005 10:55 am     Reply with quote
Hi
I have a TLC1541 (texas Instruments) 12 channel/10-bit ADC. Interface serial
http://www.lierda.com/upfile/1074129861.pdf
Im using 16F84a, PIN_A4 is pull-up(ed). I want read channnel 0....my rutine to read 10 bit is:
Main.c
#include <16f84a.h>
#fuses XT,NOWDT,NOPROTECT
#use RS232(BAUD=9600, BITS=8, PARITY=N, XMIT=PIN_A2, RCV=PIN_A4, RESTART_WDT)
#include "TLC1541.c"
float valor;
long  adc_result;
void main() {
  for(;;) {
   adc_init();
   set_adc(0);
   read_adc();
   printf("A/D Conversion using TLC1541\n\r");
   value=(float)(adc_result*25)/(float)1024;           // 0-25 Volt measure
   putc(13);
   printf("HEX Value of adc_result=%lX\n\r",adc_result);
   printf("Channel 0 Voltage= %2.2f Volts.\n\r",value);
TLC1541.c
void  delay() {            // Delay.
      delay_us(10);
void  Clock() {            // Clock signal generation
      output_high(AD_CK);
      delay();
      output_low(AD_CK);
void adc_init() {
      output_high(AD_CS);   // Be sure TLC1541 is not activated
      delay_us(10);
      output_low(AD_CS);    //Activate TLC1541, CS=0.
      delay();
      Clock();              //Valid (High to LOW) transition of CS
      Clock();              //need 2 "rising edge" of AD_CK
                            //then 1 "alling edge".
      delay();
void  set_adc(int ch) {     //Set ch selection
      int i;                // AIN0-10
      for (i=0;i<4;i++) {   // 4 "rising edges" of I/O CLOCK. MSB first
      output_bit(AD_DI,shift_left(ch,1,0));
      Clock();
      delay();
      for (i=0;i<5;i++) {   //Start sample cycle. The 10° clock is
                            //controled by read_adc();
      Clock();
      delay();              // to A/D conversion star at any time
void read_adc() {
      int i;
      Clock();                //10° Clock
      delay();
      output_high(AD_CS);     //CS=1 when I/O and System clock
                              //is same pin.
      for(i=0;i<44;i++) {     //of datasheet, 44 clock cycle for
                              //finished conversion
      Clock();
      delay();
      output_low(AD_CS);      //Activate TLC1541 again to read
                              //10 bit result stream.
      for(i=0;i<9;i++) {      //Start adc reading, 9 clocks
                              //(10 bits). Read MSB first
      shift_left(&adc_result,2,input(AD_DO));
      Clock();
      delay();
      output_high(AD_CS);     //TLC1541 is no active. End od reading.
I canīt read the 10 bit result...adc_result= 0x0000 forever......why???
Help me please
Thank you[/url]
bfemmel
PostPosted: Tue Jun 07, 2005 11:31 am     Reply with quote
densimitre,
You certainly don't give us much to go on. I need to make a lot of assumptions about what I think Clock() and delay() do in the code. One thing I see is that you are raising AD_CS high after 10 clock cycles. First of all it is active low so you should be setting it low and secondly it should be before the clock cycles and the four bit address of the channel should be on the bus at that time which since you want channel zero might be OK anyway. Just make sure that the adress input is low during this time.
If you can give us more of your program, such as the missing routines and the main body of the program we can probably make some more observations.
Good Luck
- Bruce
densimitre
PostPosted: Tue Jun 07, 2005 11:17 pm     Reply with quote
Hi
I made a change on TLC1541.c
      int i;
      for (i=0;i<4;i++) {
      if((ch&0x8)==0)
      output_low(AD_DI);
      output_high(AD_DI);
      ch <<= 1;
      Clock();
      delay();
Now I can store adc_result...and in my protoboard i had tested it, now its working.....
WOW
Thank you ...
Bye
