Can PIC16F877 do floating point math?
stevenlkz
PostPosted: Sun Jun 05, 2005 9:33 pm     Reply with quote
Hello everyone! Im doing my final project about intelligent traffic system with fuzzy logic that need to build into PIC16F877. But I face a problem that is there are no multiply, divide, square and square root instruction with MPlab. Another problem is I need to do the math in floating point. How can I solve it? Any advices and suggestions do u all can give me?
Thanks for spending your time.
Mark
PostPosted: Sun Jun 05, 2005 11:53 pm     Reply with quote
There are no asm instructions but the functionality can be accomplished through asm routines or even better yet let the C compiler do it for you and write it in C. And yes, you can do floating point math.
valemike
PostPosted: Mon Jun 06, 2005 7:18 am     Reply with quote
I see you are using MPLAB. Since you cannot use MPLAB in debug mode to reliably interpret CCS's float values, I suggest you allocate pins RC6 and RC7 for RS232 and dump your values to Hyperterminal.
Only the full CCS IDE or printf() to your RS232 will be the only means to see the results of your floating point calculations.
stevenlkz
PostPosted: Tue Jun 07, 2005 10:21 pm     Reply with quote
I know that C can do it, but I don't has C compiler, so I just can write in asm. My lecturer also want me to build in PIC16F877, can't send to PC.
Darren Rook
PostPosted: Wed Jun 08, 2005 6:51 am     Reply with quote
This is wrong.
See:
http://www.ccsinfo.com/faq/?52
rwyoung
PostPosted: Wed Jun 08, 2005 7:02 am     Reply with quote
Have you checked out the demo version for your needs?
http://www.ccsinfo.com/demo.shtml
Rob Young
Mark
PostPosted: Wed Jun 08, 2005 7:22 am     Reply with quote
Well if you can do it in C then obviously you can do it in asm since that is what the C compiler ultimately generates. Razz Microchip has math routines on their website.
RobM
PostPosted: Fri Jun 10, 2005 10:43 am     Reply with quote
You can and should use the PC for development. Connecting a serial port for this purpose is a valuable debug tool.
Rob
_______
stevenlkz
PostPosted: Sat Jun 11, 2005 10:58 pm     Reply with quote
Is the demo can compile out a Hex file? Or have other compiler other than mplab that can compile out Hex file and suitable for me to do the math operation like multiply or divide? Because the all write only can build the PIC with Hex file.
Mark
PostPosted: Sat Jun 11, 2005 11:14 pm     Reply with quote
I have no idea what you just said but
The C compiler generates a hex file.
MPLAB is an IDE that can be used with the C compiler.
The hex file generated by the compiler can be used with just about any programmer that will program a PIC.
