interrupt does not work
young
PostPosted: Thu Jun 02, 2005 9:05 am     Reply with quote
I have following program
#if defined(__PCM__)
#include <12f675.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,NOMCLR
#use rs232(baud=9600, parity=N, xmit=PIN_A0,INVERT)
void LCDSetGeometry();
void LCDReset();
void LCDinit();
void LCDSetBackLight(int8 backlit);
void LCDSetContrast(int8 contr);
void LCDClrScr();
void LCDNewLine();
void LCDCR();
void LCDTab();
void LCDVerTab();
void LCDBackSpaces(int8 bspa);
void LCDSetTab(int8 Stab);
void LCDSetCursorPos(int8 x, int8 y);
void LCDClrLine(int8 x, int8 y);
void LCDSetCursorStyle();
void LCDOnOff(int8 onoff);
int16 count;
#int_ext
void ext_isr()
count++;
  setup_comparator(NC_NC_NC_NC);  //setup_comparators(NC_NC_NC_NC); no "s"
  LCDinit();
  LCDClrScr();
  LCDSetCursorPos(0,0);
  puts("*Pulse counting*");
  count=0;
  EXT_INT_EDGE(L_TO_H);
  enable_interrupts(INT_EXT);
  LCDSetCursorPos(1,1);
  printf("Num=%lu",count);
I want to count every input to RA2, however, the count parameter does not change, and I also put led output, It looks like that the interrupt does not function at all, what is the problem?
thank you
drh
PostPosted: Thu Jun 02, 2005 9:17 am     Reply with quote
Do you mean GP2? The chip powers up with GP2 configured as an analog
input. Try setup_adc(ADC_OFF);
David
young
PostPosted: Thu Jun 02, 2005 9:49 am     Reply with quote
Thank you. That is it.
I set it
setup_adc_ports (NO_ANALOGS);
now it is changeing the count number, however, I had a new problem
when I put it low (connect to ground) and then connect to +5v, there is a increase of count, it is correct. however, when I connect to +5v, and unplug it from RB2 pin, and replug it to +5v, there is nothing change, when I unpluge it from +5v, it is suppose to be ground right? but the interrupt does not work?
I tried to put a pull down register on RB2 pin, and tried to unplug it from +5V and repluge it to +5v, this time, the count number jumps a lot, it was not increased by one, why?
PostPosted: Thu Jun 02, 2005 10:27 am     Reply with quote
The pins are CMOS inputs. They will stay at the voltage you applied for _ages_. There is nothing to make a disconnected pin go either high or low (unless you attach a pull up/down resistor either internally - where available - or externally).
The reason the count jumps a lot, is 'keybounce', If you use a mechanical contact to make a signal like this, as the signal as changed, there can be hundreds of momentary contacts as the surface irregularities come into play. This is why key scanning routines, check a key, then check it again a few mSec latter to allow the bounce time to subside.
Your system is behaving exactly as expected.
