12f683 problem
Fabricio
12f683 problem
PostPosted: Thu May 26, 2005 3:22 pm     Reply with quote
Hi, i am using the pic 12f683, ccs 3.190 and winpic800. I can read, verify and erase the microcontroller, but when i try to programme it gives me an error in direc 0x0000.
My code is:
#include <12F683.h>
#use delay(clock=8000000)
#fuses NOWDT,INTRC_IO, NOCPD, NOPROTECT, MCLR, NOPUT, NOBROWNOUT, IESO, NOFCMEN
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8)
#byte OSCCON = 0x8F
long rise;
#int_RA
RA3_isr()
rise = get_timer1();
set_timer1(0);
set_tris_a(0b001010);
OSCCON = 0x71; // Setup for 8 MHz with internal oscillator (*)
//setup_oscillator(OSC_8MHZ); // select 8MHz internal clock(*)
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
enable_interrupts(INT_RA3);
while (1)
delay_ms(2000);
printf("%lu\n\r",rise);
rise=0;
(*) I have proved both options.
Any idea??
thanks. greetings
Fabricio
PostPosted: Mon May 30, 2005 8:18 am     Reply with quote
problem solved, it was an error of configuration of the winpic
my problem now is that I set:
#use rs232 (baud=9600, parity=N, xmit=PIN_A0, rcv=PIN_A1, bits=8, restart_wdt)
but in the hyperterminal, the correct configuration is
4800.
Is it a problem of the clock??
PostPosted: Mon May 30, 2005 8:38 am     Reply with quote
4800.
I guess your clock is running at 4MHz and not at 8MHz. You still have OSCCON = 0x71 in your code? This should be the correct value for an 8MHz clock.
Or there is a bug in the CCS compiler (this is a relative new chip)....
Fabricio
PostPosted: Wed Jun 01, 2005 10:46 am     Reply with quote
new problem.
I used the restart_cause() funtion and it give me: NORMAL_POWER_UP 24.
My output is:
START
Restart=24
START
Restart=24
START
Restart=24
START
Restart=24
(reset continually) but when i put an signal in GP2(CCP1 in), the interruption is executed and prints 'XXXXXXXX......
Where is my error?
my code is:
#include <12F683.h>
#device adc=8
#fuses WDT,INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, NOBROWNOUT, NOIESO, NOFCMEN
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8,restart_wdt,errors)
#ROM 0x7FF={0x3400}
long rise;
#int_CCP1
CCP1_isr()
putc('X');
void Constructor (void);
long aux;
restart_wdt();
aux=restart_cause();
printf("Restart=%lu\n\r",aux);
printf("START\n\r");
Constructor ();
while (1)
restart_wdt();
printf("do something\r");
delay_ms(2000);
//rise=0;
restart_wdt();
set_tris_a(0b001110);
#ASM
movlw 0x8f// OSCCON
movwf 0x04
movlw 0b1100101// 4M, intternal clock, stable
movwf 0x00
movlw 0x90// OSCTUNE – OSCILLATOR TUNING
movwf 0x04
movlw 0b00000//
movwf 0x00
movlw 0x81// OPTION REG
movwf 0x04
movlw 0b11001000 // pull up dis,prescaler a wdt
movwf 0x00
movlw 0x8C// PIE1 periph interrup enable
movwf 0x04
movlw 0b00100000 // CCP1 enable
movwf 0x00
movlw 0x15//CCP1CON CCP control reg
movwf 0x04
movlw 0b00000101
movwf 0x00
movlw 0x10//T1CON
movwf 0x04
movlw 0b00000001
movwf 0x00
movlw 0x2007 // config
movwf 0x04
movlw 0b11000011011100 //
movwf 0x00
#ENDASM
setup_adc_ports(0);
setup_adc(ADC_OFF);
//setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
//setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
//setup_ccp1(CCP_CAPTURE_RE);
setup_vref(FALSE);
//enable_interrupts(INT_CCP1);
Fabricio
PostPosted: Wed Jun 01, 2005 11:18 am     Reply with quote
sorry, i forget to kick on the wdt when I use delay_ms, now it is working correctly. the correct instruction is:
#use delay (clock=4000000, restart_wdt)
PostPosted: Wed Jun 01, 2005 11:22 am     Reply with quote
Do you believe that this code works ?
movwf 0x04
movwf 0x00
What is the size of the W register ?
What does the 12F683 data sheet say (in Section 12.1) about ROM address 0x2007 ?
Fabricio
PostPosted: Wed Jun 01, 2005 1:16 pm     Reply with quote
the compiler does not generate error, nevertheless, now I am not using this piece of code.
The data sheet recommends to read “PIC12F6XX/16F6XX Memory Program-ming Specification” (DS41204). I have not read this yet.
For what I understand, only it is possible to have access to this direction during the programming.
PostPosted: Wed Jun 01, 2005 1:21 pm     Reply with quote
The data sheet says this:
Note: Address 2007h is beyond the user
program memory space. It belongs to the
special configuration memory space
(2000h-3FFFh), which can be accessed
only during programming
. See
Specification” (DS41204) for more
information.
