sadlpx
messages in an array |
Posted: Wed Jun 01, 2005 11:22 am |
I'm not a very good C programmer but here is what i'm trying to accomplish.
I have a 4 line LCD, I want the top 3 lines to be a vertically scrolling menu. My choice will always be the middle line. IF i hit enter i will know what he message is based on the current menu.
What i want
" CMD 0"
"> CMD1"
" CMD2"
" up dwn esc enter"
If i hard code each line with a series of case statment (one of each menu it works fine)
Here is what i would like to do, much easier, much shorter
STRUCT CMDS {
char C_string[19];
Const Struct CMDS C_item[10] =
{"cmd0 \n\0"},
{"cmd1 \n\0"},
{"cmd2 \n\0"},
{"cmd3 \n\0"},
{"cmd4 \n\0"},
{"cmd5 \n\0"},
{"cmd6 \n\0"},
{"cmd7 \n\0"},
{"cmd8 \n\0"},
{"cmd9 \n\0"},
void Display_Menu(int new) {
LCD_goto(2);
printf(C_item[new]);
LCD_goto(22);
printf(C_item[new +1]);
LCD_goto(42);
printf(C_item[New + 2]);
Problem is everytimeit restarts each line with "cmd0" and gets longer.
Feeling stupid |
Posted: Wed Jun 01, 2005 12:08 pm |
Post your LCD_goto() function. |
sadlpx
Posted: Wed Jun 01, 2005 12:44 pm |
Here is the function but i don't think that thast the problem
void LCD_goto( int posn ) {
putc(16); // Cursor Position command
posn = posn + 64;
putc(posn); // New LIne Position
If i hard code the origina routine ina casr atatement it works fine, only the chage to the array causes me problems. here was my original code usign 2 cases. the only difference was commenting out the fixed message and trying the array.
16f876 @10M
switch(new) {
case 0:
LCD_goto(2);
printf("*** MAIN MENU ****");
// printf(C_item[0]);
LCD_goto(22);
printf("Run Battery Test ");
// printf(C_item[1]);
LCD_goto(42);
printf("Download Data ");
// printf(C_item[2]);
case 1:
LCD_goto(2);
LCD_goto(22);
LCD_goto(42);
printf("Setup ");
break; |
Posted: Wed Jun 01, 2005 1:18 pm |
If you think there's a problem with the ROM structure, you don't
need an LCD to test it. You can test it with a terminal program.
I made the following test program. I couldn't get your code to
compile with PCM vs. 3.225. The compiler gave me this error
message on all your printf lines:
"Attempt to create a pointer to a constant"
I fixed that by adding "%s" to all your printf statements.
I also commented out your LCD_goto() statements because they
don't apply to my terminal program.
I ran the program and I got this output on my terminal window:
Hello World
cmd0
cmd1
cmd2 |
Code: | #include <16F877.H>
#use delay(clock = 4000000)
#ignore_warnings 202, 203
STRUCT CMDS {
char C_string[19];
{"cmd0 \n\0"},
{"cmd1 \n\0"},
{"cmd2 \n\0"},
{"cmd3 \n\0"},
{"cmd4 \n\0"},
{"cmd5 \n\0"},
{"cmd6 \n\0"},
{"cmd7 \n\0"},
{"cmd8 \n\0"},
{"cmd9 \n\0"},
//LCD_goto(2);
printf("%s", C_item[new]);
//LCD_goto(22);
printf("%s", C_item[new +1]);
//LCD_goto(42);
printf("%s", C_item[New + 2]);
