EEPROM addressing
Charles Linquist
EEPROM addressing
PostPosted: Tue May 31, 2005 5:18 pm     Reply with quote
In the CCS manual, it states that in the syntax of the
write_eeprom (address,value)
command on page 194, both "address" and "value" are of type int8
Is this an error? I need to address EEPROM in devices
that have 1024 bytes of EEPROM. Is there a "trick"?
Can "address" really be int16?
PostPosted: Tue May 31, 2005 6:35 pm     Reply with quote
If you have doubts about what the compiler is doing (or is capable
of doing), you should compile a test program and look at the .LST file.
Here's part of a test program for the 18F8620, which has 1024 bytes of
data eeprom. If you look in the PIC's data sheet, you can see what
registers the code refers to. I've added them below as comments.
0000                00437 ..... write_eeprom(0x3FF, 0x55);
0014 0E03           00438 MOVLW  03
0016 6EAA           00439 MOVWF  FAA   // EEADRH
0018 0EFF           00440 MOVLW  FF
001A 6EA9           00441 MOVWF  FA9   // EEADR
001C 0E55           00442 MOVLW  55
001E 6EA8           00443 MOVWF  FA8   // EEDATA
Charles Linquist
PostPosted: Tue May 31, 2005 9:51 pm     Reply with quote
Thanks!
