PIC-to-PIC Communication / Easy-radio help needed
AA
PostPosted: Tue May 31, 2005 8:54 am     Reply with quote
PROBLEM 1 - needs to be solved before problem 2
Im trying to comminicate between two pics using the rs232, im sending a simple 'F' to the reciever PIC (both 18F452). The reciever pic is connected to a PC and im monitoring the program using the hyperterminal.
Well the code (that doest work..) looks like this:
TRANSMITTER
#include <18F452.h>
#use delay(clock=12000000)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
void main (){
int k;
output_b(0x00); //
set_tris_b(0x00); // RB0 = input, resten output
while (1){
while(1){
putc('F');
output_high(PIN_B1);}
RECIEVER
#include <18F452.h>
long k=0;
char dato;
#INT_RDA
RECEPT_INTERRUPT()
printf("\n\r INTERRUPT\n");
if(kbhit()) {
dato=getc();
printf("\rRecieved: %u times looped: %lu",dato,k);}
void go(){
output_high(diod5);
delay_ms(10);
output_low(diod5);
delay_ms(10);
/*dato=getc();*/
k++;
void init(){
enable_interrupts(int_rda);
ENABLE_INTERRUPTS(GLOBAL);
printf("\n\rSTARTING\n");
output_b(0x00);
set_tris_b(0x00);
void main (){
printf("\n\rStart 1");
init();
while(1){
go();
HYPERTERMINAL
The hyper terminal says the following if i run the program for lets say 1 minute:
Start 1
INTERRUPT
Recieved: 0 times looped: 0
STARTING
INTERRUPT
Recieved : 70 times looped: 35
INTERRUPT
Recieved: 70 times looped: 35
after this nothing more happens no mather how long i run it.
Any help appreciated as im running out of time badly
Problem 2, is a problem because problem 1 exists, well:Im trying to radiocontrol a robot with help from Easy-Radio:
DATASHEET
Well im trying to send simple go forward, back, left etc but i cant get the radio communication to work at all :( even if it says simple and my projekt time is running out bad :(
Oh and the PIC:s i use are 2x18F452 (transmitter and reciever)
On the transmitter i have connected:
PIN 1 (RF GND) - GND
PIN 2 (RF OUT) - Antenna
PIN 3 (Vcc) - +5V
PIN 4 (Gnd) - GND
PIN 5 (TXD) - RC6/TX on the pic (18F452)
On the reciever
PIN 1 (Antenna) - Antenna
PIN 2 (RF Gnd) - GND
PIN 3 (RSSI) - Inget
PIN 4 (Busy output) -GND
PIN 5 (Serial data out) - RC7/RX on pic
PIN 6 (Serial data in) - +5v
PIN 7 (Host ready input) - GND
PIN 8 (Vcc) - +5v
PIN 9 (Ground) - GND
The transmitters code is like this:
while (1){
printf("\n Sending...");
if i connect RC6 på the transmitter pic toMAX232 and the hyperterminal så i do get the correct print - >
Sending...
Sending...
etc..
And the recivers code is
char radioinput = 0;
int k=0;
while(1){
radioinput=getc();
printf("\rRadio input: %u varv:",radioinput,k);
It goes one loop (k) and then i halts andi guess it is because it doesnt get anything on the getch().
Both PIC:s are initiated like this:
#include <18F452.h>
Im very happy over all the help i can get! Smile
PostPosted: Tue May 31, 2005 3:07 pm     Reply with quote
Read all the posts about keeping interrupt handlers _short_. Your transmit code is sending 'F' characters flat out. The receive code, interrupts, and before it even attempts to read the character, spends 13 character times printing a message. This _will not work_. The fact that the intetrrupt occurs, means there is a character waiting to be read (you do not need to use 'kbhit'), and it _must_ be read inside two character times, or the UART buffers will overflow.
Look at the siow.c example, on how to buffer a received character, and do _all_ your other work in the main code. Even with buffering, the buffer _will_ overflow if a single incoming character triggers a message more than one character long.
Also add 'ERRORS' to your RS232 setup in the receiver, which will clear the overrun error, and allow the code to continue (though not make it work properly as written).
