long_data
Jan Noman
long_data
PostPosted: Sat May 28, 2005 4:47 am     Reply with quote
#useRS232(....long_data...) valid for software ,hardware or both of UART ?
regards
Jan
PostPosted: Sat May 28, 2005 6:38 am     Reply with quote
It is valid for both the hardware AND software UART. Using the specified pins the compiler will know if it has to use the inbuilt hardware UART or create a software equivalent.
Please note that there are some differences between the hardware and software UART. The most important differences are that the software UART won't generate interrupts and with the hardware UART you can't use the INVERT option.
If you want to use a software UART on pins assigned to a hardware UART then add the force_sw option.
