question for "PCM Programmer" and your median_filt
valemike
PostPosted: Thu May 26, 2005 11:26 am     Reply with quote
Hi PCMProg,
A few weeks ago, i decided to use your median_filter() code that you put on this forum in the past. Basically, i'm reading my A/D continuously in my main()'s while(1) loop. There are occasions though where i have a sub-loop that may run for a 1-2 seconds, and will starve the median_filter() from running. The next time i do call the median_filter() function, I then have a few stale values in my array.
Is there a way to "flush" this array?
I figure maybe i can just invoke the function 7 times to flush out any stale data. Or should I just re-initialize the static variables inbuf_index and num_elements to zero?
Thanks,
Mike
Your original code below...
int16 median_filter(int16 latest_element)
    static int16 input_buffer[MEDIAN_FILTER_WIDTH];
    static char inbuf_index = 0;
    static char num_elements = 0;
    int16 sorted_data[MEDIAN_FILTER_WIDTH];
    int16 median;
    // Insert incoming data element into circular input buffer.
    input_buffer[inbuf_index] = latest_element;
    inbuf_index++;
    if(inbuf_index >= MEDIAN_FILTER_WIDTH)  // If index went past buffer end
       inbuf_index = 0;       // then reset it to start of buffer
    if(num_elements < MEDIAN_FILTER_WIDTH)
       num_elements++;
    // THIS LINE MAY NOT BE NEEDED IF SORTED DATA IS STATIC.
    memset(sorted_data, 0, MEDIAN_FILTER_WIDTH * 2);
    // Copy input data buffer to the (to be) sorted data array.
    memcpy(sorted_data, input_buffer, num_elements * 2);   // memcpy works on bytes
    // Then sort the data.
    Insertion_Sort_16(sorted_data, MEDIAN_FILTER_WIDTH);
   // During the first few calls to this function, we have fewer
   // elements in the sorted data array than the filter width.
   // So to compensate for that, we pick the median from the number
   // of elements that are available.  ie, if we have 3 elements,
   // we pick the middle one of those as the median.
   // Also, because the sort function sorts the data from low to high,
   // we have to calculate the index from the high end of the array.
   median = sorted_data[MEDIAN_FILTER_WIDTH - 1 - num_elements/2];
   return(median);
PostPosted: Thu May 26, 2005 3:10 pm     Reply with quote
You could add some code near the start of the routine,
and add a 2nd parameter to force an init if it's = TRUE,
and then just exit.
int16 median_filter(int16 latest_element, int8 init)
    int16 median;
    if(init == TRUE)
       inbuf_index = 0;
       num_elements = 0;
       return(0);
Call it with the 2nd parameter = TRUE to do the init.
median_filter(0, TRUE);
Call it normally like this:
median_filter(value, FALSE);
Or, you can do it whatever way you want.
valemike
PostPosted: Thu May 26, 2005 3:20 pm     Reply with quote
ok thanks. i think i'll do that.
