How to ShiftOut and ShiftIN in CCS? (Like PicBasicPro)
jahan
PostPosted: Mon May 23, 2005 8:52 am     Reply with quote
If I have a 2 wire device with CLK and DAT, can somebody show me a very simple example of sending data out using CCS C?
For example an LCD which only has CLK and DAT lines and I have want to show "Hello".
Thankx
Mark
PostPosted: Mon May 23, 2005 10:56 am     Reply with quote
#define OUT_CLOCK   PIN_B1
#define OUT_DO      PIN_B2
void ShiftOut (int8 data)
  output_low(OUT_CLOCK);
  if((data&0x80)==0)
    output_low(OUT_DO);
    output_high(OUT_DO);
  data <<= 1;
  output_high(OUT_CLOCK);
jahan
does ShiftIN works the same way?
PostPosted: Mon May 23, 2005 1:02 pm     Reply with quote
Thank you for your posting.
It's very clean & clear.
can I ask you if ShiftIN works the same way but backward? and can you post a sample for ShiftIN?
Thankx again.
Mark
PostPosted: Mon May 23, 2005 1:57 pm     Reply with quote
Take a look at 74165.c in your examples folder
bfemmel
PostPosted: Mon May 23, 2005 2:21 pm     Reply with quote
Actually, 74165.c is in the Drivers folder on my setup with 3.224 so it may be there for you too.
- Bruce
Mark
PostPosted: Mon May 23, 2005 2:46 pm     Reply with quote
You are correct. My mistake.
rnielsen
PostPosted: Wed May 25, 2005 1:09 pm     Reply with quote
Just an FYI...
If you use
....................   if(!(data&0x80))
0028:  BTFSC  06.7
002A:  BRA    0032
instead of
....................   if((data&0x80)==0)
0028:  MOVF   06,W
002A:  ANDLW  80
002C:  XORLW  00
002E:  BNZ   0036
you will save two commands in case you are worried about speed. This was compiled for a 18F452.
Ronald
Futterama
PostPosted: Tue Oct 18, 2005 7:05 am     Reply with quote
  if((data&0x80)==0)
    output_low(OUT_DO);
  data <<= 1;
How does this code work? I don't see how every bit is clocked out in this code, it doesn't loop as far as I can tell.
And I can't find information regarding this line: "data <<= 1;"
What does that line do?
I can't make it work :-/
Mark
PostPosted: Tue Oct 18, 2005 7:10 am     Reply with quote
It should be in a loop
  int8 i;
  for (i=0;i<8;i++)
    if((data&0x80)==0)
      output_low(OUT_DO);
    data <<= 1;
same as
data = data<<1;
And if you don't know what << does, then it is shift left so the statement shifts 1 bit to the left. If you look at the driver files it will show you.
PostPosted: Thu Oct 20, 2005 3:43 pm     Reply with quote
That code don't work right either.
If i send 0b10100100 I get 0b10100101.
Futterama
PostPosted: Thu Oct 20, 2005 5:44 pm     Reply with quote
Sorry, my browser didn't log me in automatically.
I know what my problem was, I needed shift right, not shift left.
Thanks for you help anyways Wink
Mark
PostPosted: Thu Oct 20, 2005 6:50 pm     Reply with quote
Get it where?
Futterama
PostPosted: Fri Oct 21, 2005 2:49 am     Reply with quote
Get it where?
Mark, my mistake, thought I got that out of OUT_DO, but I was wrong.
I fixed it to work with my program, and I thank you for your help, no need to dig into it further.
