Software uart2 - Cant call function
burnsy
PostPosted: Mon May 23, 2005 6:58 am     Reply with quote
Problem 2
After invoking a software uart with the #use statement, I can use the putc() function to pass a char to a seriaL printer. However, if I call a function with a putc() in it, it doesn't work?
eg
myputc('A');
void
myputc(char x)
putc(x);
This doesn't work, but a normal putc('A'); DOES work.
Looks like a compiler problem, as this works on my old 16F processors. Pulling my hair out.. need help ;) Thanks everyone
This is the last code change until its ready....
SherpaDoug
PostPosted: Mon May 23, 2005 7:01 am     Reply with quote
Is there any chance you are running out of stack space? Look at the calling tree vs the stack depth for your processor.
burnsy
PostPosted: Tue May 24, 2005 6:56 am     Reply with quote
Stack space seems to be ok. List files says level 5 + 2 for interrupts. The call that doesn't seem to work is only 3 function calls into the stack, I think?
If you saw my other post RE comms problems, it would seem I have a compiler problem, or, the whole thing setup wrong.
regards
burnsy
PostPosted: Wed May 25, 2005 2:33 am     Reply with quote
Hi everyone,
turned out to be the compiler. 3.209 works perfectly Smile
