bootloader CCS example in DEBUG mode
moutinho
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Fri May 20, 2005 2:48 pm     Reply with quote
Does the MPLAB environment using the ICD2 uses the lower part of the flash memory in order to debug the code? Can I run the bootloader demo that comes with the CCS in debug mode step by step ? If the MPLAB in debug mode with ICD2 uses the lower flash memory, I can corrupt debuging.
Compiler CCS 3.206 and pic 18f6720.
Thanks in advance,
Andre
PostPosted: Fri May 20, 2005 3:16 pm     Reply with quote
The list of PIC resources used by ICD2 is buried deep within the
MPLAB help file. Here is a quick way to find it:
1. Start MPLAB and click on the Help menu. Click on "Topics".
Then select "MPLAB ICD2".
2. The Help window will be displayed. Click on the Search tab.
3. Type "Resources" into the search box and click the List Topics button.
4. Many topics will be displayed. Click on this one: PIC18F6XXX/8XXX Devices
5. A table will be displayed on the right. Find your PIC in the table
and you will see the resources that the ICD2 uses.
moutinho
PostPosted: Mon May 23, 2005 7:24 am     Reply with quote
Thanks,
Andre
