Pavel Kolinko
How do I pass a generic pin argument to a function? |
Posted: Fri May 20, 2005 2:10 pm |
I haven't been able to figure out a way to do the following task, which would be very useful in a variety of functions that I have written.
At the moment I am implementing an SPI bus (in software), so I will use it as an example.
Here is a function that sends 1 byte via SPI:
Code: | #define DEV_ENABLE PIN_C5
#define SDATA PIN_C4
#define SCLK PIN_C3
/* insert lots of main() code here :grin: */
void SPI_send8(BYTE data)
BYTE i;
output_low(ENABLE);
for(i=0;i<8;++i)
output_bit(SDATA, shift_left(&data,1,0));
output_high(SCLK);
output_low (SCLK);
output_high(DEV_ENABLE);
Here is the problem:
In order to implement the SPI bus && keep the SPI_send8 function generic, the function needs to know which ENABLE line to use.
I would like to pass to the function an extra argument to make DEV_ENABLE a variable, instead of a constant.
However, I don't want to put an if-else type structure inside the function.
I would like to pass the ENABLE pin address to the function directly.
The problem is that the PINS are all boolean, so I can't pass by reference
(pointers) .
Here is a pseudo code that demonstrates the idea,
but unfortunately is not possible:
Code: | #define DEV1_ENABLE PIN_C6
#define DEV2_ENABLE PIN_C5
#define SCLK PIN_C3
int1 *ptr_device_enable_ID;
if(DEVICE_1)
ptr_device_enable_ID=DEV1_ENABLE;
ptr_device_enable_ID=DEV2_ENABLE;
/* again, lots of other code here */
void SPI_send8(BYTE data, int1 *ptr_device_enable_ID)
BYTE i;
output_low(ptr_device_enable_ID);
for(i=0;i<8;++i)
output_high(SCLK);
output_low (SCLK);
output_high(ptr_device_enable_ID);
If I could pass the addresses of the pins in variable/pointer/structure form
to the functions directly,
it would eliminate the need to pass to the functions a bunch of flags.
Writing if-else or switch() for every function to test for the flags
seems like a big waste of ROM, since it is known ahead of time
which data line needs to be used.
Any advice would be much appreciated!
Thanks,
Pavel |
Pavel Kolinko
Posted: Fri May 20, 2005 2:21 pm |
Thank you!
I will check these out! |
Posted: Fri May 20, 2005 2:38 pm |
No 'warranties' here, writing these without testing, but it should be possible to do this with something like:
#define NUMPORTS (5)
int8 IOarray[numports];
#byte IOarray = 0xF80
#define set_bit(x) IOarray[(x-PIN_A0)>>3]=IOarray[(x-PIN_A0)>>3]|(1<<(x&3))
#define clear_bit(x) IOarray[(x-PIN_A0)>>3]=IOarray[(x-PIN_A0)>>3]&((1<<(x&3))^0xFF)
This for a 18F chip with five I/O ports.
Might be worth an 'experiment'.
Posted: Fri May 20, 2005 2:42 pm |
I know that you posted some functions too, recently, and I wanted
to post a link to them as well, but I couldn't find them. |
Posted: Fri May 20, 2005 3:13 pm |
Yes, I think I posted some routines earlier, but these macros, are an 'off the cuff' attempt to make a generic form that is compact, and should work with the standard pin numbers from the CCS include file.
Posted: Fri May 20, 2005 3:54 pm |
Using the bit set and bit clear functions will make the macros quicker, so:
#define set_bit(x) bit_set(IOarray[(x-PIN_A0)>>3],(x&3))
#define clear_bit(x) bit_clear(IOarray[(x-PIN_A0)>>3],(x&3))
Or:
#define set_bit(x) bit_set(*(int8 *)((x-PIN_A0)>>3),(x&3))
#define clear_bit(x) bit_clear(*(int8 *)((x-PIN_A0)>>3),(x&3))
I reckon these must be approaching the simplest versions possible, and ought to work for any of the processors, using the standard pin defintions, passed to functions (as a 'long' though).
So you can for example code:
void flashbit(int16 bit) {
set_bit(bit);
delay_us(50);
clear_bit(bit);
void main(void) {
int16 pin;
while (1) {
for (pin=PIN_A0;pin<=PIN_A5;pin++)
flashbit(pin);
This must be the closest approach to the standard 'fixed' operation, in a simple form.
