Problem pointing into a structure
jerrybrowse
PostPosted: Fri May 20, 2005 9:25 am     Reply with quote
I have a problem accessing data within a structure. The structure is:
struct maxfio
    int max_rcv[32];
    int *p_rcv;
    int rcv_chksm;
} maxfcb[4];
max_rcv is a buffer for serial data coming in.
*p_rcv is the pointer to access it.
Assuming dbyte is an int8 and block is an int8, and the pointer is correctly
set, I use the following that works:
    dbyte=*(maxfcb[0].p_rcv)++;            // hard maxfcb index reference
However, if I use a variable, 'block', whose value is 0 thus:
    dbyte=*(maxfcb[block].p_rcv)++;     // varible maxfcb index reference
this does not work.
Is this incorrect syntax or is the compiler confused?
mike holeton
PostPosted: Fri May 20, 2005 9:36 am     Reply with quote
Have you defined block any where? int, char, etc. I think the compiler is confussed, because it does not know what block is.
jerrybrowse
PostPosted: Fri May 20, 2005 9:41 am     Reply with quote
Thanks for the reply Mike.
No, I'm afraid block is defined (as an int8) and is set to a value which in this case is zero (hex).
Regards
Jerry
