need a cost efficient 8 bit DAC
nader
PostPosted: Wed May 18, 2005 9:24 am     Reply with quote
could some one guide me for selecting a cost efficient 8 bit DAC
that needed single power supply.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed May 18, 2005 10:25 am     Reply with quote
My favorite is MAX517/MAX518. Single/dual channel, I2C interface.
If you want something really cost efficient, you could run PWM output into an RC filter. It will make a poor man's DAC. However, this approach is a lot less precise.
DragonPIC
PostPosted: Wed May 18, 2005 12:25 pm     Reply with quote
and monitor it with an ADC channel.
-Matt
kender
PostPosted: Thu May 19, 2005 3:09 am     Reply with quote
DragonPIC,
Could you post the code, which runs this closed loop?
Thanks,
Nick
DragonPIC
PostPosted: Thu May 19, 2005 12:40 pm     Reply with quote
I guess I could scronge up the code I created for out HV PS. This was done on a small 12F675 and isn't the way I would do it on a larger PIC (with a PWM), so it wouldn't make such a good example. It pulses a switching circuit and the resulting voltage is read back from a voltage divider. The ripple is kept to a minimum by a cap. and the fact that I can vary how often I pulse it by reading the result back with the ADC.
Also, not my design so I wouldn't feel right posting the code.
-Matt
