Statements necessary?
Christophe
PostPosted: Thu May 19, 2005 1:39 am     Reply with quote
look at this code please:
setup_psp(PSP_DISABLED);
setup_vref(FALSE);
while (1)
Those 3 setup statements put: * The PSP off
* The comparator module off
The question is: Is this necessary? IF I put nothing or that, isn't that the same? (on power-on, all peripherals are disabled by default?)
thank you
PostPosted: Thu May 19, 2005 4:02 am     Reply with quote
Remember that you can arrive at the start of the program, by other routes than a POR. If (for instance), you have stack overflow reset enabled, or brownout reset enabled, you will arrive at the start of the program, with the state of the devices 'indeterminate'. Also though some devices show themselves as disabled by default, there are a suprising number of erratum relating to the startup behaviour. Putting things into a 'known' state, is safer programming, but in many cases parts at last of this can be skipped, if you are sure the system will only start from a power-on state...
Christophe
PostPosted: Mon May 23, 2005 2:10 am     Reply with quote
Dear Hamlett;
ok I understand that that is safer programming. But what can you say of the status of all I/O ports after a brownout reset or so?
telmah
PostPosted: Mon May 23, 2005 4:06 am     Reply with quote
Depends on the chip.
_Normally_, the default 'reset' state is warranted for POR, and BOR, _but not_ for a watchdog reset. This is the case for most chips, but there are a couple with erratas over this, which do not reset everything, even in the BOR state.
