RS232 Question
jahan
RS232 Question
PostPosted: Sun May 15, 2005 7:13 pm     Reply with quote
if a system is sending out the following values:
int go = 254 //start trasmit signal
int RN = 1 // as the relay number from 1 to 12
int SN = 1 // as the status of relay 0 or 1
putc(go);
putc(RN);
putc(SN);
the baud rate on the transmit side is as follow:
#use rs232(baud=2400,parity=N,bits=8,xmit=PIN_A4,INVERT)
The transmitter is fine and working OK.
Now I want to read these values on another controller using CCS.
Can somebody help figure out how to read these values on the receiving side?
the receiving side wait for 254 and then reads the next 2 values as Relay Number and Relay status.
PhilWinder
PostPosted: Sun May 15, 2005 9:50 pm     Reply with quote
Try doing some examples first, since they are not too hard to get working (assuming your harware is correct). Take a look at getc() in the manual. Once you have, then apply them to this task. If you figure something out, you will have a much greater understanding and a great sense of achievment. Smile
phil
jahan
Let's try again.
PostPosted: Sun May 15, 2005 10:51 pm     Reply with quote
Thank you for your reply.
I've tried many hours to figure this out.
here is what I've done so far:
#include <16F84A.h>
#fuses XT,NOPROTECT,NOWDT,NOPUT
void main (void) {
  set_tris_b(0b00000000);
  set_tris_a(0b00010000);
  while (true) {
    k = getc();
    m = getc();
    n = getc();
    if (k == 254) {
      if (m == 1) {
        if (n == 2) {
          output_high(PIN_B0);
PostPosted: Mon May 16, 2005 5:05 am     Reply with quote
You don't say what chip you are using?. Are you dead sure the transmit is 'OK'. The reason I ask, is that pin A4, on a lot of the newer chips, is an 'open collector' drive, only able to pull the signal low, and requiring a pull-up resistor to work as a drive to another logic input....
SherpaDoug
Re: Let's try again.
PostPosted: Mon May 16, 2005 8:01 am     Reply with quote
Pin B0 is not going to do much if it is not an output. If you are using standard IO you don't need the tris statements. For a test try this:
#include <16F84A.h>
void main (void) {
  set_tris_b(0b00000011);
  while (getc() != 254);   //wait for 254
  output_high(PIN_B1);
  if (getc() == 1) {         // test that the next character is 1
        if (getc() == 2) {
output_low(PIN_B1);
