SPI transition
tophe59
SPI transition
PostPosted: Sun May 15, 2005 11:31 am     Reply with quote
I have problems wihth SPI. I want configure SPI in 16F876 in master mode and low to high transition
my code is:
   set_tris_c(0x50);//port c 0=en sortie
   setup_ccp1(ccp_pwm);// mode pwm
   setup_ccp2(ccp_pwm);//
   setup_timer_2(T2_DIV_BY_16,255,1);
   set_pwm1_duty(125); // 50%
   set_pwm2_duty(125); // 50%
   setup_ccp1(ccp_off);// off
   setup_ccp2(ccp_off);// off
   setup_spi(spi_master|SPI_L_TO_H|spi_clk_div_64);
//   setup_spi(spi_master|SPI_H_TO_L|spi_clk_div_64);
   //for (;;) {output_bit(pin_b0,input(pin_a3));} //boucle sans fin
   //   for (;;) {output_c(read_adc());} //boucle sans fin
   for (;;) {
      output_low(sel);
      delay_us(10);
      vartemp=spi_read(0x80);
      delay_us(10);
      for (i=0;i<5;i++) {valpsx[i]=spi_read(0x42); //42
      delay_us(10);}
      //vartemp=spi_read(0xff);
      //delay_us(10);
      //delay_us(10);
      //delay_us(10);
      output_high(sel);
      delay_us(100);
i use 3.183 ccs version
When i see signals with osciloscope the transition clock of SPI is High to Low and no low to high Crying or Very sad
help me please Crying or Very sad
lst code:
....................    set_tris_c(0x50);//port c 0=en sortie
000A:  MOVLW  FF
000B:  BCF    03.5
000C:  MOVWF  28
000D:  MOVLW  50
000E:  BSF    03.5
000F:  MOVWF  07
0010:  BCF    03.5
0011:  MOVWF  28
....................    setup_ccp1(ccp_pwm);// mode pwm
0012:  BCF    28.2
0013:  MOVF   28,W
0014:  BSF    03.5
0015:  MOVWF  07
0016:  BCF    03.5
0017:  BCF    07.2
0018:  MOVLW  0C
0019:  MOVWF  17
....................    setup_ccp2(ccp_pwm);//
001A:  BCF    28.1
001B:  MOVF   28,W
001C:  BSF    03.5
001D:  MOVWF  07
001E:  BCF    03.5
001F:  BCF    07.1
0020:  MOVLW  0C
0021:  MOVWF  1D
....................    setup_timer_2(T2_DIV_BY_16,255,1);
0022:  MOVLW  00
0023:  MOVWF  78
0024:  IORLW  06
0025:  MOVWF  12
0026:  MOVLW  FF
0027:  BSF    03.5
0028:  MOVWF  12
....................    set_pwm1_duty(125); // 50%
0029:  MOVLW  7D
002A:  BCF    03.5
002B:  MOVWF  15
....................    set_pwm2_duty(125); // 50%
002C:  MOVWF  1B
....................    setup_ccp1(ccp_off);// off
002D:  BSF    28.2
002E:  MOVF   28,W
002F:  BSF    03.5
0030:  MOVWF  07
0031:  BCF    03.5
0032:  CLRF   17
0033:  CLRF   17
....................    setup_ccp2(ccp_off);// off
0034:  BSF    28.1
0035:  MOVF   28,W
0036:  BSF    03.5
0037:  MOVWF  07
0038:  BCF    03.5
0039:  CLRF   1D
003A:  CLRF   1D
....................    setup_spi(spi_master|SPI_L_TO_H|spi_clk_div_64);
003B:  BCF    14.5
003C:  BCF    28.5
003D:  MOVF   28,W
003E:  BSF    03.5
003F:  MOVWF  07
0040:  BCF    03.5
0041:  BSF    28.4
0042:  MOVF   28,W
0043:  BSF    03.5
0044:  MOVWF  07
0045:  BCF    03.5
0046:  BCF    28.3
0047:  MOVF   28,W
0048:  BSF    03.5
0049:  MOVWF  07
004A:  MOVLW  22
004B:  BCF    03.5
004C:  MOVWF  14
004D:  MOVLW  00
004E:  BSF    03.5
004F:  MOVWF  14
.................... //   setup_spi(spi_master|SPI_H_TO_L|spi_clk_div_64);
....................    //for (;;) {output_bit(pin_b0,input(pin_a3));} //boucle sans fin
....................    //   for (;;) {output_c(read_adc());} //boucle sans fin
....................    for (;;) {
....................       output_low(sel);
0050:  BCF    03.5
0051:  BCF    28.7
0052:  MOVF   28,W
0053:  BSF    03.5
0054:  MOVWF  07
0055:  BCF    03.5
0056:  BCF    07.7
....................       delay_us(10);
0057:  MOVLW  10
0058:  MOVWF  77
0059:  DECFSZ 77,F
005A:  GOTO   059
005B:  NOP
....................       vartemp=spi_read(0x80);
005C:  MOVF   13,W
005D:  MOVLW  80
005E:  MOVWF  13
005F:  BSF    03.5
0060:  BTFSC  14.0
0061:  GOTO   064
0062:  BCF    03.5
0063:  GOTO   05F
0064:  BCF    03.5
0065:  MOVF   13,W
0066:  MOVWF  22
0067:  MOVLW  10
0068:  MOVWF  77
0069:  DECFSZ 77,F
006A:  GOTO   069
006B:  NOP
....................       for (i=0;i<5;i++) {valpsx[i]=spi_read(0x42); //42
006C:  CLRF   23
006D:  MOVF   23,W
006E:  SUBLW  04
006F:  BTFSS  03.0
0070:  GOTO   086
0071:  MOVLW  24
0072:  ADDWF  23,W
0073:  MOVWF  04
0074:  MOVF   13,W
0075:  MOVLW  42
0076:  MOVWF  13
0077:  BSF    03.5
0078:  BTFSC  14.0
0079:  GOTO   07C
007A:  BCF    03.5
007B:  GOTO   077
007C:  BCF    03.5
007D:  MOVF   13,W
007E:  MOVWF  00
....................       delay_us(10);}
007F:  MOVLW  10
0080:  MOVWF  77
0081:  DECFSZ 77,F
0082:  GOTO   081
0083:  NOP
0084:  INCF   23,F
0085:  GOTO   06D
....................       //vartemp=spi_read(0xff);
....................       //delay_us(10);
....................       output_high(sel);
0086:  BCF    28.7
0087:  MOVF   28,W
0088:  BSF    03.5
0089:  MOVWF  07
008A:  BCF    03.5
008B:  BSF    07.7
....................       delay_us(100);
008C:  MOVLW  A6
008D:  MOVWF  77
008E:  DECFSZ 77,F
008F:  GOTO   08E
0090:  NOP
0091:  BSF    03.5
0092:  GOTO   050
0093:  SLEEP
PostPosted: Sun May 15, 2005 1:41 pm     Reply with quote
I think your version has a bug with setup_spi().
You can fix it by adding the following function to your code.
This function will properly setup the CKP and CKE bits in
the SPI control registers.
// These register address are for the 16F877.
// Refer to the data sheet if you use a different PIC.
#byte SSPCON  = 0x14
#byte SSPSTAT = 0x94
#bit  CKE = SSPSTAT.6
#bit  CKP = SSPCON.4
#bit  SSPEN = SSPCON.5
// SPI mode 0:  CKP = 0 and CKE = 1
// SPI mode 1:  CKP = 0 and CKE = 0
// SPI mode 2:  CKP = 1 and CKE = 1
// SPI mode 3:  CKP = 1 and CKE = 0
void change_spi_mode(char mode)
SSPEN = 0;   // Disable the SPI module
mode &= 0x03;
// Set the CKP and CKE bits to select the desired SPI mode.
switch(mode)
   case 0:
     CKP = 0;
     CKE = 1;
   case 1:
     CKP = 0;
     CKE = 0;
   case 2:
     CKP = 1;
     CKE = 1;
   case 3:
     CKP = 1;
     CKE = 0;
SSPEN = 1;   // Re-enable the SPI module
Inside your program, you can use it as shown below.
First call the CCS function, setup_spi(). Then call the
change_spi_mode() function to set the mode properly.
Example:
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_64);
change_spi_mode(0);    // Select mode 0
tophe
PostPosted: Mon May 16, 2005 5:19 am     Reply with quote
That work thanks Very Happy
tophe59
PostPosted: Wed Oct 12, 2005 3:16 pm     Reply with quote
Same bug with 18f4620 but not work.
I have change the @ for 18f4620
#byte SSPCON = 0xfc6
#byte SSPSTAT = 0xfc7
help me pleeaaaase Crying or Very sad
PostPosted: Wed Oct 12, 2005 4:41 pm     Reply with quote
What is your version of the PCH compiler ?
PostPosted: Thu Oct 13, 2005 12:11 am     Reply with quote
tophe59
PostPosted: Thu Oct 13, 2005 11:10 am     Reply with quote
up Confused
PostPosted: Thu Oct 13, 2005 12:08 pm     Reply with quote
Post a very short, but complete program that shows the problem.
Tell us exactly what your problem is. Don't just say "not work".
tophe59
PostPosted: Thu Oct 13, 2005 12:17 pm     Reply with quote
Thank's PCM
Data is transmit high to low. i want transmit low to high
the code
#byte SSPCON  = 0xfc6 //0x14
#byte SSPSTAT = 0xfc7 //0x94
#bit  CKP = SSPCON.4
mode &= 0x03;
switch(mode)
   case 0:
     CKP = 0;CKE = 1;break;
   case 1:
     CKP = 0;CKE = 0;break;
   case 2:
     CKP = 1;CKE = 1;break;
   case 3:
     CKP = 1;CKE = 0;break;
   change_spi_mode(1);
PostPosted: Thu Oct 13, 2005 12:50 pm     Reply with quote
You want to transmit data on the rising edge of clock.
That means that your SPI slave device will sample
the data on the falling edge, which is SPI mode 1.
Change your code to this:
setup_spi(spi_master | SPI_L_TO_H | spi_clk_div_64);
change_spi_mode( 1 );
tophe59
PostPosted: Thu Oct 13, 2005 12:58 pm     Reply with quote
Excuse me PCM, the mode is already mode(1).
I editing message...
PostPosted: Thu Oct 13, 2005 1:10 pm     Reply with quote
What SPI slave chip are you using ?
tophe59
PostPosted: Thu Oct 13, 2005 1:13 pm     Reply with quote
I use PSX joystick. But i see the bad transition with an oscilloscope ( good in english ?)
PostPosted: Thu Oct 13, 2005 1:42 pm     Reply with quote
I wonder if you have confused the SCK and SDO pins ?
You didn't post a complete test program, so I have posted one below.
Change the #fuses statement and the #use delay() statement
to fit your hardware.
1. Then compile it and look at the SCK and SDO pins with your
oscilloscope.
2. Try changing the parameter in the change_spi_mode()
function to different values (0, 1, 3). See if it works.
3. If not, then post the .LST file.
(For security reasons, you don't have to post your CCS customer
number, which is at the top of the .LST file, right after the compiler version. Just delete that number when you post the .LST file).
#include <18F4620.H>
#bit  CKP = SSPCON.4
mode &= 0x03;
switch(mode)
   case 0:
   case 1:
   case 2:
   case 3:
change_spi_mode(1);
   spi_write(0x55);
tophe59
PostPosted: Thu Oct 13, 2005 1:57 pm     Reply with quote
i'm confused that work (low to high) in mode(0)
Thank's PCM you're my saver !
