Does the ccs function write_program_memory() work???
moutinho
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Thu May 12, 2005 2:38 pm     Reply with quote
I have implemented the following code:
int8 data[2];
data[0] = 0x0;
data[1] = 0x1;
erase_program_eeprom(0x1000);
write_program_memory(0x1000, data, 2);
I have checked Program Memory windows and notice the address
0x1000 still kept NOP (0x0000) value.
thanks,
Andre
PostPosted: Thu May 12, 2005 3:53 pm     Reply with quote
1. What is your PIC ?
2. What is your version of the compiler ?
3. I guess you must be running this in the simulator,
so the version of MPLAB will also be important.
It may not work in the simulator. For example,
look at some of the articles about this problem
on the Microchip forum:
http://forum.microchip.com/tm.asp?m=86239&mpage=1&key=program+memory&anchor#86260
http://forum.microchip.com/tm.asp?m=80348&mpage=1&key=program+memory&anchor#80348
Just as a general rule, never trust that any hardware process
will work in the simulator. Always assume the simulator
is flakey, rather than the compiler. It's more likely.
Then check the Microchip forum.
PostPosted: Fri May 13, 2005 1:59 am     Reply with quote
Also add the comment that it is very important not to have any interrupts running when you call the write.
kometen
PostPosted: Fri May 13, 2005 4:37 am     Reply with quote
Yes, it works fine for me with e.g. the 18F452 PIC.
Remember when you use the function that you
must use pointer to the variable
The correct code is:
write_program_memory(0x1000, &data, 2);
Remember to upload the program memory, otherwise you wont see the data in the program memory window.
Check it with
read_program_memory(0x1000, data, 2);
Good luck
Poul
moutinho
PostPosted: Fri May 13, 2005 7:31 am     Reply with quote
PCM programmer wrote:
HI,
PIC18F6720
3.206
Ok, Thanks
>http://forum.microchip.com/tm.asp?>m=86239&mpage=1&key=program+memory&anchor#86260
>http://forum.microchip.com/tm.asp?>m=80348&mpage=1&key=program+memory&anchor#80348
moutinho
PostPosted: Fri May 13, 2005 8:05 am     Reply with quote
The data variable is declared as
int8 data[32];
So, when I call
The pointer of data is passed to the function.
If I try compiling as write_program_memory(0x1000, &data, 2) I get a compiler error.
Upload program memory is the same as pressing button "Read target device" ???
Its still not working Sad
Thanks,
Andre
Check it with
Good luck
Poul
moutinho
PostPosted: Fri May 13, 2005 8:07 am     Reply with quote
HI,
PIC18F6720
3.206
Ok, Thanks
moutinho
PostPosted: Fri May 13, 2005 8:08 am     Reply with quote
Also tried
disable_interrupts(GLOBAL);
read_program_memory(0x1000, data_read, 2);
Thanks,
Andre
PostPosted: Fri May 13, 2005 8:25 am     Reply with quote
moutinho wrote:
Also tried
Thanks,
Andre
You are still passing the value, not the _address_ of the value.
mrbmcg
PostPosted: Thu Jul 07, 2005 7:59 am     Reply with quote
In my experience the CCS debugger won't modify the ROM window when you write to it and it just remains the same.
Best way to check is to read it back using read_program_memory() into some RAM variable and check it in the debugger.
As good as the debugger is for many things it's still a long way off being bulletproof IMHO.
Still much better than any of the competition, again IMHO
