Instruction 0x0000 jumps to wrong address
object01
PostPosted: Wed May 11, 2005 12:49 pm     Reply with quote
When I debug the following program (PIC-C v3.223, ICD FW v1.39), and reset while looking at the listing, then step, I'm observing that the first instruction, GOTO 0068, does not actually go to 0068. Instead, it jumps to 002A. The program does not produce "HELLO WORLD" on the debugger.
Source:
#include <18F4620.h>
#device adc=8
#fuses NOWDT,WDT128,INTRC_IO, NOPROTECT, NOIESO, NOBROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, LPT1OSC, NOMCLR
#use delay(clock=8000000)
#use rs232(xmit=PIN_B5, rcv=PIN_B5, stream=DEBUGGER)
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   printf("HELLO WORLD");
List:
CCS PCH C Compiler, Version 3.223, 25633               11-May-05 13:45
               Filename: C:\Documents and Settings\jas.MICRONOVATECH\Desktop\Experiments\4620 fprintf\main.LST
               ROM used: 228 bytes (0%)
                         Largest free fragment is 64476
               RAM used: 6 (0%) at main() level
                         7 (0%) worst case
               Stack:    1 locations
0000:  GOTO   0068
....................  #include <18F4620.h>
....................  //////// Standard Header file for the PIC18F4620 device ////////////////
.................... #device PIC18F4620
.................... #list
.................... #device adc=8
.................... #fuses NOWDT,WDT128,INTRC_IO, NOPROTECT, NOIESO, NOBROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, LPT1OSC, NOMCLR
.................... #use delay(clock=8000000)
.................... #use rs232(xmit=PIN_B5, rcv=PIN_B5, stream=DEBUGGER)
0020:  BCF    F93.5
0022:  BCF    F8A.5
0024:  MOVLW  08
0026:  MOVWF  01
0028:  NOP
002A:  NOP
002C:  NOP
002E:  BSF    01.7
0030:  BRA    0050
0032:  BCF    01.7
0034:  RRCF   07,F
0036:  BTFSC  FD8.0
0038:  BSF    F8A.5
003A:  BTFSS  FD8.0
003C:  BCF    F8A.5
003E:  BSF    01.6
0040:  BRA    0050
0042:  BCF    01.6
0044:  DECFSZ 01,F
0046:  BRA    0034
0048:  NOP
004A:  NOP
004C:  NOP
004E:  BSF    F8A.5
0050:  MOVLW  3E
0052:  MOVWF  FE9
0054:  DECFSZ FE9,F
0056:  BRA    0054
0058:  NOP
005A:  NOP
005C:  BTFSC  01.7
005E:  BRA    0032
0060:  BTFSC  01.6
0062:  BRA    0042
0064:  GOTO   00DC (RETURN)
.................... void main() {
0068:  CLRF   FF8
006A:  BCF    FD0.7
006C:  CLRF   FEA
006E:  CLRF   FE9
0070:  MOVF   FC1,W
0072:  ANDLW  C0
0074:  IORLW  0F
0076:  MOVWF  FC1
0078:  MOVLW  07
007A:  MOVWF  FB4
007C:  MOVF   FB4,W
007E:  BCF    FA1.6
0080:  MOVLW  70
0082:  MOVWF  FD3
0084:  BCF    F93.5
0086:  BSF    F8A.5
....................    setup_adc_ports(NO_ANALOGS|VSS_VDD);
0088:  MOVF   FC1,W
008A:  ANDLW  C0
008C:  IORLW  0F
008E:  MOVWF  FC1
....................    setup_adc(ADC_OFF|ADC_TAD_MUL_0);
0090:  BCF    FC2.0
....................    setup_psp(PSP_DISABLED);
0092:  BCF    F96.4
....................    setup_spi(FALSE);
0094:  BCF    FC6.5
0096:  BCF    F94.5
0098:  BSF    F94.4
009A:  BCF    F94.3
009C:  MOVLW  00
009E:  MOVWF  FC6
00A0:  MOVWF  FC7
....................    setup_wdt(WDT_OFF);
00A2:  BCF    FD1.0
....................    setup_timer_0(RTCC_INTERNAL);
00A4:  MOVLW  80
00A6:  MOVWF  FD5
....................    setup_timer_1(T1_DISABLED);
00A8:  CLRF   FCD
....................    setup_timer_2(T2_DISABLED,0,1);
00AA:  MOVLW  00
00AC:  MOVWF  FCA
00AE:  MOVLW  00
00B0:  MOVWF  FCB
....................    setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
00B2:  MOVF   FB1,W
00B4:  ANDLW  48
00B6:  MOVWF  FB1
....................    setup_comparator(NC_NC_NC_NC);
00B8:  MOVLW  07
00BA:  MOVWF  FB4
00BC:  MOVF   F92,W
00BE:  MOVLW  06
00C0:  MOVWF  00
00C2:  DECFSZ 00,F
00C4:  BRA    00C2
00C6:  NOP
00C8:  MOVF   FB4,W
00CA:  BCF    FA1.6
....................    setup_vref(FALSE);
00CC:  CLRF   FB5
....................    printf("HELLO WORLD");
00CE:  CLRF   06
00D0:  MOVF   06,W
00D2:  RCALL  0004
00D4:  INCF   06,F
00D6:  MOVWF  00
00D8:  MOVWF  07
00DA:  BRA    0020
00DC:  MOVLW  0B
00DE:  SUBWF  06,W
00E0:  BNZ   00D0
00E2:  BRA    00E2
Configuration Fuses:
   Word  1: 0800   NOIESO INTRC_IO NOFCMEN RESERVED
   Word  2: 0E19   NOBROWNOUT WDT128 NOWDT BORV21 NOPUT
   Word  3: 0500   CCP2C1 NOPBADEN LPT1OSC NOMCLR
   Word  4: 0001   STVREN DEBUG NOLVP NOXINST RESERVED
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
Humberto
PostPosted: Wed May 11, 2005 4:00 pm     Reply with quote
1) The first goto should point to the main() starting.
2) If you are using the ICD, your code donīt shows that. It doesnīt have the #ICD=TRUE directive.
3) Ovbiously you have got this code from the project wizard, assuming you are just starting,
what is the reason to use this code:
instead of the simplest form until you get it running,
#use rs232(xmit=PIN_B5)
If you had defined only one Comm port, do not use STREAM at this step. Once you get
this minimal configuration running properly, add the other features.
Best wishes,
Humberto
Humberto
PostPosted: Wed May 11, 2005 4:10 pm     Reply with quote
that this minimal configuration can run properly, add the other features.
Best wishes,
Humberto
object01
PostPosted: Wed May 11, 2005 6:02 pm     Reply with quote
1) It does point to main starting, but the actual jump moves the program counter to 002A, not 0068.
2) The compiler implicitly adds the necessary ICD code when we enter debug mode. I generally keep #ICD=TRUE out of my programs to conserve program space in standalone mode.
3) No good reason, other than it's the way we do it in all our other programs.
Jeff S.
Humberto
PostPosted: Thu May 12, 2005 7:37 am     Reply with quote
I dont have the 18F4620 but I tested with 18F452
PCW v3.221, ICD FW v1.29 Rev#163.
It works fine with and without the DEBUG mode.
The actual jump moves the program counter to 0040.
0000:  GOTO   main
....................  #include <18F452.h>
....................  //////// Standard Header file for the PIC18F452 device ////////////////
.................... #device PIC18F452
.................... #device ICD=TRUE
.................... #fuses NOWDT,WDT128,XT, NOPROTECT, BROWNOUT, PUT, NOCPD, STVREN,\
....................        NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC
.................... #use delay(clock=4000000)
.................... #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,enable=PIN_C5)
0020:  BCF    TRISC.5
0022:  BSF    LATC.5
0024:  BTFSS  PIR1.4
0026:  BRA    0024
0028:  MOVFF  ??65535,TXREG
002C:  NOP
002E:  BCF    TRISC.5
0030:  BSF    LATC.5
0032:  BTFSS  TXSTA.1
0034:  BRA    0032
0036:  BCF    TRISC.5
0038:  BCF    LATC.5
003A:  GOTO   009C (RETURN)
003E:  CLRF   TBLPTRU
0040:  BCF    RCON.7
0042:  CLRF   FSR0H
0044:  CLRF   FSR0L
0046:  BSF    ADCON1.0
0048:  BSF    ADCON1.1
004A:  BSF    ADCON1.2
004C:  BCF    ADCON1.3
004E:  BCF    TRISC.5
0050:  BCF    LATC.5
0052:  MOVLW  19
0054:  MOVWF  SPBRG
0056:  MOVLW  26
0058:  MOVWF  TXSTA
005A:  MOVLW  90
005C:  MOVWF  RCSTA
....................    setup_adc_ports(NO_ANALOGS);
005E:  BSF    ADCON1.0
0060:  BSF    ADCON1.1
0062:  BSF    ADCON1.2
0064:  BCF    ADCON1.3
0066:  BCF    TRISE.4
0068:  BCF    SSPCON.5
006A:  BCF    TRISC.5
006C:  BSF    TRISC.4
006E:  BCF    TRISC.3
0070:  MOVLW  00
0072:  MOVWF  SSPCON
0074:  MOVWF  SSPSTAT
0076:  BCF    WDTCON.0
0078:  MOVLW  80
007A:  MOVWF  T0CON
007C:  CLRF   T1CON
007E:  MOVLW  00
0080:  MOVWF  T2CON
0082:  MOVLW  00
0084:  MOVWF  PR2
0086:  MOVF   T3CON,W
0088:  ANDLW  48
008A:  MOVWF  T3CON
....................    printf("Hello word");
008C:  CLRF   @@06
008E:  MOVF   @@06,W
0090:  RCALL  0004
0092:  INCF   @@06,F
0094:  MOVWF  @00
0096:  MOVFF  00,??65535
009A:  BRA    0020
009C:  MOVLW  0A
009E:  SUBWF  @@06,W
00A0:  BNZ   008E
00A2:  BRA    00A2
   Word  1: 2100   XT NOOSCSEN
   Word  2: 0E0E   BROWNOUT WDT128 NOWDT BORV20 PUT
   Word  3: 0100   CCP2C1
   Word  6: E00F   NOWRT NOWRTD NOWRTB NOWRTC
Humberto
object01
PostPosted: Thu May 12, 2005 1:38 pm     Reply with quote
Talked with Kampurath at CCS and he found a workaround for the jump problem. He had me alter the ICD style for the 18Fx620 using the device editor, such that the forced fuses included NOSTVREN instead of STVREN. This solved the GOTO problem. He said this fix would be included in the next release (current release is 3.224).
However, I still can't get printf output to appear in the debug monitor, despite seeing the ASCII on the scope.
Jeff S.
Masaya
Jump to 0x002A on 18F2620
PostPosted: Fri May 13, 2005 7:41 am     Reply with quote
Thank you for good information. After I also had used 18F2620, it encountered the same problem
(jump to 0x002a). Very Happy
