Pic16f877 I/O & A/D
Pic16f877 I/O & A/D
PostPosted: Tue May 10, 2005 8:31 am     Reply with quote
I've got an existing little project that is configured for all analog (eight A/D's) on a pic 16f877. I'd like to see if I couldn't use this existing project and add a mux to it to expand the number of A/D inputs. I've got ports A2, E1, and E2 available for the channel selects. Is it possible to set these as output I/O's where they can be swung high or low and leave the existing a/d inputs? Do I use the set_tris() function?
Thanks.
valemike
PostPosted: Tue May 10, 2005 9:25 am     Reply with quote
Yes you can use tris settings to select the 3 select pins. Set them as outputs.
However, I don't think you can get more A/D inputs with a Mux (?) since i thought a mux only works with logic levels.
There are some PICs out there with several more ADC channels if that interests you.
mkent
PostPosted: Tue May 10, 2005 11:45 am     Reply with quote
Maxium makes TTL/CMOS controlled analog mux's. Try this link
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2064
Good luck, Mick
guest
PostPosted: Tue May 10, 2005 2:46 pm     Reply with quote
Thanks for the replies.
I was thinking about using this one from Analog Devices.
http://www.analog.com/en/prod/0%2C2877%2CADG608%2C00.html
SC
I need some experiments in PIC16f877
PostPosted: Sun Feb 11, 2007 6:43 am     Reply with quote
I need help is there someone who would like to give me some sample experiments. for specific, how to display my result in a/d conversion to LCD.
