PCM - How to tell if putc() will block
gustnado
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Fri May 06, 2005 3:24 pm     Reply with quote
I want a little snippet of code that will tell me if putc() will block before I call it (my application cannot afford to be hung up in a read or write).
I wrote one for the 18F452 in assembly:
while(1) {
    #asm
    btfss 0xF9E.4           //UART Ready? (PIE2)
    bra   notrdy
    #endasm
    charssent++;
    putc(c);
    return;
    notrdy:
    defer();
However, the analogous code does not work on the 18F877A. It is
#define PIE1 0x8c
    while(1) {
        #asm
        btfss PIE1.4
        goto  notrdy
        #endasm
        charssent++;
        putc(c);
        return;
        notrdy:
        defer();
This code never writes anything.
Any ideas?
The best weather is bad weather
rwyoung
PostPosted: Fri May 06, 2005 3:44 pm     Reply with quote
OK, some questions.
Why are you reading the enable bit for the transmit interrupt?
Wouldn't you be better off trying to read the status of TXIF in PIR1 or TRMT in TXSTA?
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
gustnado
PostPosted: Fri May 06, 2005 3:59 pm     Reply with quote
Because of a dumb mistake. I had tried TXSTA before without success but I suspect it was a syntactical screwup.
The following appears to work:
void sendChar(int c)
    while(1) {
        #asm
   btfss 0x98,1
   goto  notrdy
   #endasm
   charssent++;
   putc(c);
   return;
   notrdy:
   defer();
Which leads to the next question: does setjmp/longjmp work on this processor (16F877A)?
rwyoung
PostPosted: Sat May 07, 2005 11:43 am     Reply with quote
There is a running discussion about the setjump/longjump commands and how they work.
I haven't really kept up but as I understand it, they work but not very well and not under all conditions. Also some dependence on your compiler revision and the chip type.
Didn't help much did it...
My advice would be to think long and hard about a way to NOT use setjump and longjump in your code.
Rob Young
