Guest Guest
Pic18F452 programming error |
Posted: Sat May 07, 2005 6:47 am |
Can anyone tell me why after programming this pic 3 or 4 times, the following error occurs: "CODE PROGRAMMING ERROR AT 0000". I am usinng EPIC programmer with EPICWIN software version 2.45 Beta.
This happens almost with every pic 18f452, i do the same with the pic16f877 and it never fails.
Once the 18f452 fails it becomes useless. |
Guest Guest
Posted: Sat May 07, 2005 6:50 am |
I almost forgot, i dont use LVP and i checked the conections and are OK.
i think it is just a PIC problem or something like that. |
Posted: Sat May 07, 2005 11:27 am |
You should go to Google and search for that error message, and put it in
quotes so Google will search for the complete string. Like this:
You get a lot of good hits, with a FAQ, and a user board, etc.. I looked
at three of the hits, and each one has high qualitly information.
Use Google first, and use quoted strings. It works.
http://www.google.com |
Guest Guest
Posted: Sat May 07, 2005 7:34 pm |
I know google, i tried searching it b4 posting, but i only found problems refered to LVP or programmer malfunction, and this is not the case. My programmer works fine. I just posted this here because i know that many experienced PIC users posts here and i wanted to know if somethin similar occured to them.
Anyway thanks for your reply. |
