RS232
Einly
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger ICQ Number
RS232
PostPosted: Fri May 06, 2005 4:11 am     Reply with quote
Dear all,
I try to transfer RS232 data from the computer to PIC16f876. In the computer, I am using Visual C WriteFile Function. In the PIC16f876, I use an interrupt to check for data. If the first byte sent is 2 (ID), the following byte will be received. However, I noticed that only the first byte is received instead. May I know how should I solve this problem?
#include <16f876.h>
#fuses hs,NOPROTECT,NOLVP,PUT,BROWNOUT,NOWDT
#use rs232(baud=115200,xmit=PIN_C6,rcv=PIN_C7,PARITY=N)
#include <lcd.c>
#byte PORTA=5
#byte PORTB=6
#byte PORTC=7
byte status=0;
byte smain=0;
#int_rda
void serial_isr()
a=getc();
if(a==2 && status==0)
status=1;
else if(status==1)
status=0;
smain=1;
set_tris_a(0);
setup_port_a(no_analogs);
set_tris_b(0);
set_tris_c(0x85);
lcd_init();
enable_interrupts(int_rda);
enable_interrupts(global);
do
if(smain==1)
if(a==18)
lcd_putc("\f GRAB");
else if(a==14)
lcd_putc("\f LED 1");
}while(1);
Einly
yanickch
RS232
PostPosted: Fri May 06, 2005 7:34 am     Reply with quote
do
if(smain==1)
if(a==18)
else if(a==14)
} <---------- you need that here
}while(1);
bye Yanickch
