How 2 make a TP-UD field encoder for PDU-SMS mode
densimitre
PostPosted: Wed Apr 20, 2005 11:53 pm     Reply with quote
Hi
I need my PIC send SMS in PDU mode.....but i want that PIC generate the User Data field of PDU frame..not using predefined PDU message...
because I have something like this:
int ad=getadc()
float val=5*ad/255;
sprintf(buffer,"The Value is=%2.3f",val);
The idea is store the string "The Value.." in buffer string, then encode to TP-UD this buffer, then strcat()ing the others PDU field strings to send entire SMS mesage..
Thank you very much
densimitre
PostPosted: Sat Apr 30, 2005 11:41 pm     Reply with quote
Hi
I found this code:
http://www.nerdlabs.org/downloads/pduconv/pduconv-0.1.zip
It converts ASCII string to 7bit string like PDU, but ist for ANSI C...
Who can modificate it for CCS??
Thank you
densimitre
PostPosted: Mon May 02, 2005 11:12 pm     Reply with quote
I have this code, but ist not work:
#include <16f84.h>
#use RS232(BAUD=9600, BITS=8, PARITY=N, XMIT=PIN_B4, RCV=PIN_B5)
//#device icd=true
//#include <stdio.h>
//#include <string.h>
//#include <stdlibm.h>  // Libreria que incluye la funcion malloc()
#include "pduconv.c"      // Funciones y tablas para la conversion de ASCII a PDU
//#include "pduconv.h"    // Fichero con definicion de las funciones
int main()
   char buffer[]="Esta es una Prueba"
   int pdulen, i;
   unsigned char *pdu;
   pdulen=ascii_to_pdu(buffer,&pdu);
   for (i=0; i<pdulen;i++)
   printf("%02hX",pdu[i]);
   free(pdu);
pduconv.c
 * Functions for converting between an ISO-8859-1 ASCII string and a
 * PDU-coded string as described in ETSI GSM 03.38 and ETSI GSM 03.40.
 * This code is released to the public domain in 2003 by Mats Engstrom,
 * Nerdlabs Consulting. ( matseng at nerdlabs dot org )
#include <string.h>
//#include <stdlib.h>     Ma be this .h ist not have in CCS
#include <STDLIBM.H>
#define VERSION 0.1
/* Define Non-Printable Characters as a question mark */
#define NPC7    63
#define NPC8    '?'
    This lookup table converts from ISO-8859-1 8-bit ASCII to the
    7 bit "default alphabet" as defined in ETSI GSM 03.38
    ISO-characters that don't have any correspondning character in the
    7-bit alphabet is replaced with the NPC7-character.  If there's
    a close match between the ISO-char and a 7-bit character (for example
    the letter i with a circumflex and the plain i-character) a substitution
    is done. These "close-matches" are marked in the lookup table by
    having its value negated.
    There are some character (for example the curly brace "}") that must
    be converted into a 2 byte 7-bit sequence.  These characters are
    marked in the table by having 256 added to its value.
int lookup_ascii8to7[]={
    NPC7,       /*     0      null [NUL]                              */
    NPC7,       /*     1      start of heading [SOH]                  */
    NPC7,       /*     2      start of text [STX]                     */
    NPC7,       /*     3      end of text [ETX]                       */
    NPC7,       /*     4      end of transmission [EOT]               */
    NPC7,       /*     5      enquiry [ENQ]                           */
    NPC7,       /*     6      acknowledge [ACK]                       */
    NPC7,       /*     7      bell [BEL]                              */
    NPC7,       /*     8      backspace [BS]                          */
    NPC7,       /*     9      horizontal tab [HT]                     */
    10,         /*    10      line feed [LF]                          */
    NPC7,       /*    11      vertical tab [VT]                       */
    10+256,     /*    12      form feed [FF]                          */
    13,         /*    13      carriage return [CR]                    */
    NPC7,       /*    14      shift out [SO]                          */
    NPC7,       /*    15      shift in [SI]                           */
    NPC7,       /*    16      data link escape [DLE]                  */
    NPC7,       /*    17      device control 1 [DC1]                  */
    NPC7,       /*    18      device control 2 [DC2]                  */
    NPC7,       /*    19      device control 3 [DC3]                  */
    NPC7,       /*    20      device control 4 [DC4]                  */
    NPC7,       /*    21      negative acknowledge [NAK]              */
    NPC7,       /*    22      synchronous idle [SYN]                  */
    NPC7,       /*    23      end of trans. block [ETB]               */
    NPC7,       /*    24      cancel [CAN]                            */
    NPC7,       /*    25      end of medium [EM]                      */
    NPC7,       /*    26      substitute [SUB]                        */
    NPC7,       /*    27      escape [ESC]                            */
    NPC7,       /*    28      file separator [FS]                     */
    NPC7,       /*    29      group separator [GS]                    */
    NPC7,       /*    30      record separator [RS]                   */
    NPC7,       /*    31      unit separator [US]                     */
    32,         /*    32      space                                   */
    33,         /*    33    ! exclamation mark                        */
    34,         /*    34    " double quotation mark                   */
    35,         /*    35    # number sign                             */
    2,          /*    36    $ dollar sign                             */
    37,         /*    37    % percent sign                            */
    38,         /*    38    & ampersand                               */
    39,         /*    39    ' apostrophe                              */
    40,         /*    40    ( left parenthesis                        */
    41,         /*    41    ) right parenthesis                       */
    42,         /*    42    * asterisk                                */
    43,         /*    43    + plus sign                               */
    44,         /*    44    , comma                                   */
    45,         /*    45    - hyphen                                  */
    46,         /*    46    . period                                  */
    47,         /*    47    / slash,                                  */
    48,         /*    48    0 digit 0                                 */
    49,         /*    49    1 digit 1                                 */
    50,         /*    50    2 digit 2                                 */
    51,         /*    51    3 digit 3                                 */
    52,         /*    52    4 digit 4                                 */
    53,         /*    53    5 digit 5                                 */
    54,         /*    54    6 digit 6                                 */
    55,         /*    55    7 digit 7                                 */
    56,         /*    56    8 digit 8                                 */
    57,         /*    57    9 digit 9                                 */
    58,         /*    58    : colon                                   */
    59,         /*    59    ; semicolon                               */
    60,         /*    60    < less-than sign                          */
    61,         /*    61    = equal sign                              */
    62,         /*    62    > greater-than sign                       */
    63,         /*    63    ? question mark                           */
    0,          /*    64    @ commercial at sign                      */
    65,         /*    65    A uppercase A                             */
    66,         /*    66    B uppercase B                             */
    67,         /*    67    C uppercase C                             */
    68,         /*    68    D uppercase D                             */
    69,         /*    69    E uppercase E                             */
    70,         /*    70    F uppercase F                             */
    71,         /*    71    G uppercase G                             */
    72,         /*    72    H uppercase H                             */
    73,         /*    73    I uppercase I                             */
    74,         /*    74    J uppercase J                             */
    75,         /*    75    K uppercase K                             */
    76,         /*    76    L uppercase L                             */
    77,         /*    77    M uppercase M                             */
    78,         /*    78    N uppercase N                             */
    79,         /*    79    O uppercase O                             */
    80,         /*    80    P uppercase P                             */
    81,         /*    81    Q uppercase Q                             */
    82,         /*    82    R uppercase R                             */
    83,         /*    83    S uppercase S                             */
    84,         /*    84    T uppercase T                             */
    85,         /*    85    U uppercase U                             */
    86,         /*    86    V uppercase V                             */
    87,         /*    87    W uppercase W                             */
    88,         /*    88    X uppercase X                             */
    89,         /*    89    Y uppercase Y                             */
    90,         /*    90    Z uppercase Z                             */
    60+256,     /*    91    [ left square bracket                     */
    47+256,     /*    92    \ backslash                               */
    62+256,     /*    93    ] right square bracket                    */
    20+256,     /*    94    ^ circumflex accent                       */
    17,         /*    95    _ underscore                              */
    -39,        /*    96    ` back apostrophe                         */
    97,         /*    97    a lowercase a                             */
    98,         /*    98    b lowercase b                             */
    99,         /*    99    c lowercase c                             */
    100,        /*   100    d lowercase d                             */
    101,        /*   101    e lowercase e                             */
    102,        /*   102    f lowercase f                             */
    103,        /*   103    g lowercase g                             */
    104,        /*   104    h lowercase h                             */
    105,        /*   105    i lowercase i                             */
    106,        /*   106    j lowercase j                             */
    107,        /*   107    k lowercase k                             */
    108,        /*   108    l lowercase l                             */
    109,        /*   109    m lowercase m                             */
    110,        /*   110    n lowercase n                             */
    111,        /*   111    o lowercase o                             */
    112,        /*   112    p lowercase p                             */
    113,        /*   113    q lowercase q                             */
    114,        /*   114    r lowercase r                             */
    115,        /*   115    s lowercase s                             */
    116,        /*   116    t lowercase t                             */
    117,        /*   117    u lowercase u                             */
    118,        /*   118    v lowercase v                             */
    119,        /*   119    w lowercase w                             */
    120,        /*   120    x lowercase x                             */
    121,        /*   121    y lowercase y                             */
    122,        /*   122    z lowercase z                             */
    40+256,     /*   123    { left brace                              */
    64+256,     /*   124    | vertical bar                            */
    41+256,     /*   125    } right brace                             */
    61+256,     /*   126    ~ tilde accent                            */
    NPC7,       /*   127      delete [DEL]                            */
    NPC7,       /*   128                                              */
    NPC7,       /*   129                                              */
    -39,        /*   130      low left rising single quote            */
    -102,       /*   131      lowercase italic f                      */
    -34,        /*   132      low left rising double quote            */
    NPC7,       /*   133      low horizontal ellipsis                 */
    NPC7,       /*   134      dagger mark                             */
    NPC7,       /*   135      double dagger mark                      */
    NPC7,       /*   136      letter modifying circumflex             */
    NPC7,       /*   137      per thousand (mille) sign               */
    -83,        /*   138      uppercase S caron or hacek              */
    -39,        /*   139      left single angle quote mark            */
    -214,       /*   140      uppercase OE ligature                   */
    NPC7,       /*   141                                              */
    NPC7,       /*   142                                              */
    NPC7,       /*   143                                              */
    NPC7,       /*   144                                              */
    -39,        /*   145      left single quotation mark              */
    -39,        /*   146      right single quote mark                 */
    -34,        /*   147      left double quotation mark              */
    -34,        /*   148      right double quote mark                 */
    -42,        /*   149      round filled bullet                     */
    -45,        /*   150      en dash                                 */
    -45,        /*   151      em dash                                 */
    -39,        /*   152      small spacing tilde accent              */
    NPC7,       /*   153      trademark sign                          */
    -115,       /*   154      lowercase s caron or hacek              */
    -39,        /*   155      right single angle quote mark           */
    -111,       /*   156      lowercase oe ligature                   */
    NPC7,       /*   157                                              */
    NPC7,       /*   158                                              */
    -89,        /*   159      uppercase Y dieresis or umlaut          */
    -32,        /*   160      non-breaking space                      */
    64,         /*   161    ¡ inverted exclamation mark               */
    -99,        /*   162    ¢ cent sign                               */
    1,          /*   163    £ pound sterling sign                     */
    36,         /*   164    ¤ general currency sign                   */
    3,          /*   165    ¥ yen sign                                */
    -33,        /*   166    ¦ broken vertical bar                     */
    95,         /*   167    § section sign                            */
    -34,        /*   168    ¨ spacing dieresis or umlaut              */
    NPC7,       /*   169    © copyright sign                          */
    NPC7,       /*   170    ª feminine ordinal indicator              */
    -60,        /*   171    « left (double) angle quote               */
    NPC7,       /*   172    ¬ logical not sign                        */
    -45,        /*   173    ­ soft hyphen                             */
    NPC7,       /*   174    ® registered trademark sign               */
    NPC7,       /*   175    ¯ spacing macron (long) accent            */
    NPC7,       /*   176    ° degree sign                             */
    NPC7,       /*   177    ± plus-or-minus sign                      */
    -50,        /*   178    ² superscript 2                           */
    -51,        /*   179    ³ superscript 3                           */
    -39,        /*   180    ´ spacing acute accent                    */
    -117,       /*   181    µ micro sign                              */
    NPC7,       /*   182    ¶ paragraph sign, pilcrow sign            */
    NPC7,       /*   183    · middle dot, centered dot                */
    NPC7,       /*   184    ¸ spacing cedilla                         */
    -49,        /*   185    ¹ superscript 1                           */
    NPC7,       /*   186    º masculine ordinal indicator             */
    -62,        /*   187    » right (double) angle quote (guillemet)  */
    NPC7,       /*   188    ¼ fraction 1/4                            */
    NPC7,       /*   189    ½ fraction 1/2                            */
    NPC7,       /*   190    ¾ fraction 3/4                            */
    96,         /*   191    ¿ inverted question mark                  */
    -65,        /*   192    À uppercase A grave                       */
    -65,        /*   193    Á uppercase A acute                       */
    -65,        /*   194    Â uppercase A circumflex                  */
    -65,        /*   195    Ã uppercase A tilde                       */
    91,         /*   196    Ä uppercase A dieresis or umlaut          */
    14,         /*   197    Å uppercase A ring                        */
    28,         /*   198    Æ uppercase AE ligature                   */
    9,          /*   199    Ç uppercase C cedilla                     */
    -31,        /*   200    È uppercase E grave                       */
    31,         /*   201    É uppercase E acute                       */
    -31,        /*   202    Ê uppercase E circumflex                  */
    -31,        /*   203    Ë uppercase E dieresis or umlaut          */
    -73,        /*   204    Ì uppercase I grave                       */
    -73,        /*   205    Í uppercase I acute                       */
    -73,        /*   206    Î uppercase I circumflex                  */
    -73,        /*   207    Ï uppercase I dieresis or umlaut          */
    -68,        /*   208    Ð uppercase ETH                           */
    93,         /*   209    Ñ uppercase N tilde                       */
    -79,        /*   210    Ò uppercase O grave                       */
    -79,        /*   211    Ó uppercase O acute                       */
    -79,        /*   212    Ô uppercase O circumflex                  */
    -79,        /*   213    Õ uppercase O tilde                       */
    92,         /*   214    Ö uppercase O dieresis or umlaut          */
    -42,        /*   215    × multiplication sign                     */
    11,         /*   216    Ø uppercase O slash                       */
    -85,        /*   217    Ù uppercase U grave                       */
    -85,        /*   218    Ú uppercase U acute                       */
    -85,        /*   219    Û uppercase U circumflex                  */
    94,         /*   220    Ü uppercase U dieresis or umlaut          */
    -89,        /*   221    Ý uppercase Y acute                       */
    NPC7,       /*   222    Þ uppercase THORN                         */
    30,         /*   223    ß lowercase sharp s, sz ligature          */
    127,        /*   224    à lowercase a grave                       */
    -97,        /*   225    á lowercase a acute                       */
    -97,        /*   226    â lowercase a circumflex                  */
    -97,        /*   227    ã lowercase a tilde                       */
    123,        /*   228    ä lowercase a dieresis or umlaut          */
    15,         /*   229    å lowercase a ring                        */
    29,         /*   230    æ lowercase ae ligature                   */
    -9,         /*   231    ç lowercase c cedilla                     */
    4,          /*   232    è lowercase e grave                       */
    5,          /*   233    é lowercase e acute                       */
    -101,       /*   234    ê lowercase e circumflex                  */
    -101,       /*   235    ë lowercase e dieresis or umlaut          */
    7,          /*   236    ì lowercase i grave                       */
    7,          /*   237    í lowercase i acute                       */
    -105,       /*   238    î lowercase i circumflex                  */
    -105,       /*   239    ï lowercase i dieresis or umlaut          */
    NPC7,       /*   240    ð lowercase eth                           */
    125,        /*   241    ñ lowercase n tilde                       */
    8,          /*   242    ò lowercase o grave                       */
    -111,       /*   243    ó lowercase o acute                       */
    -111,       /*   244    ô lowercase o circumflex                  */
    -111,       /*   245    õ lowercase o tilde                       */
    124,        /*   246    ö lowercase o dieresis or umlaut          */
    -47,        /*   247    ÷ division sign                           */
    12,         /*   248    ø lowercase o slash                       */
    6,          /*   249    ù lowercase u grave                       */
    -117,       /*   250    ú lowercase u acute                       */
    -117,       /*   251    û lowercase u circumflex                  */
    126,        /*   252    ü lowercase u dieresis or umlaut          */
    -121,       /*   253    ý lowercase y acute                       */
    NPC7,       /*   254    þ lowercase thorn                         */
    -121        /*   255    ÿ lowercase y dieresis or umlaut          */
 * Use a lookup table to convert from an ISO-8859-1 string to
 * the 7-bit default alphabet used by SMS.
 *  *ascii   The string to convert
 *  **a7bit  A pointer to the array that the result is stored in,
 *           the space is malloced by this function
 *  Returns the length of the a7bit-array
 *  Note:  The a7bit-array must be free()'ed by te caller
static int convert_ascii_to_7bit(char *ascii, char **a7bit) {
    int r;
    int w;
    r=0;
    w=0;
    /* Allocate sufficient memory for the result string */
    *a7bit=malloc(strlen(ascii)*2+1);
    while (ascii[r]!=0) {
        if ((lookup_ascii8to7[(unsigned char)ascii[r]])<256) {
            (*a7bit)[w++]=abs(lookup_ascii8to7[(unsigned char)ascii[r++]]);
        } else {
            (*a7bit)[w++]=27;
            (*a7bit)[w++]=lookup_ascii8to7[(unsigned char)ascii[r++]]-256;
    /* Realloc the result array to the correct size */
    *a7bit=realloc(*a7bit,w);
    return w;
 *  Convert an ISO-8859-1 ASCII string to an array of PDU-coded bytes
 *  *ascii  The ISO-cleartext to convert
 *  **pdu   Pointer to an array where the pdu-bytes will be stored in, this
 *          function allocates the neccesary memory for the array
 *  Returns the number of bytes stored in the pdu-array
 *  Note:  Don't forget to free() the pdu-array when you're finished with it.
int ascii_to_pdu(char *ascii, unsigned char **pdu) {
    int r;
    int w;
    char *ascii7bit;
    int  len7bit;
    /* Start by converting the ISO-string to a 7bit-string */
    len7bit=convert_ascii_to_7bit(ascii,&ascii7bit);
    *pdu=malloc(len7bit);
    /* Now, we can create a PDU string by packing the 7bit-string */
    r=0;
    w=0;
    while (r<len7bit) {
        (*pdu)[w]=((ascii7bit[r]>>(w%7))&0x7F) | ((ascii7bit[r+1]<<(7-(w%7)))&0xFF);
        if ((w%7)==6) r++;
        r++;
        w++;
    free(ascii7bit);
    return w;
and pduconv.h:
#ifndef _PDU_H_
#define _PDU_H_
int ascii_to_pdu(char *ascii, unsigned char **pdu);
I had try to compile, but it have many error..
It seems than this code is not for CCS, especially in pduconv.c please help me...
Thnak you very much
densimitre
PostPosted: Mon May 02, 2005 11:14 pm     Reply with quote
Its possible make a pointer to a pointer???
Richter
PostPosted: Tue May 03, 2005 5:22 am     Reply with quote
A GOOOD QUESTION!
I m sorry to get offtopic but it s very important this question:
can I create a double pointer?
like this
char** a;
?? I have tried it too, but only an error occurred! Shocked
Why I get all these strange problems ?
PostPosted: Tue May 03, 2005 7:49 am     Reply with quote
Use:
char *a[];
instead.
Remember in C, there is a cross equivalence between arrays and pointers. The declaration makes 'a', an array of pointers to characters. You can access an element of the array, using 'a' as a pointer, and *(a+5), will be the item in the sixth array entry, which will itself be a pointer to a character.
densimitre
PostPosted: Tue May 03, 2005 2:32 pm     Reply with quote
Ttelmah wrote:
Use:
char *a[];
instead.
WOW...thank you very much..
In this moment, i had finished to make the changes of the code....and pic c compile it...but ist very expensive in RAM/ROM use...perhaps I would have to use a 18F series PIC.....
ROM used: 3198 (21%)
          3198 (21%) including unused fragments
          2 Average locations per line
          11 Average locations per statement
RAM used: 158 (21%) at main() level
          211 (28%) worst case
Lines Stmts  %   Files
   20     5   2  C:\SMS\main.c
  267     0   0  C:\PICC\devices\18f242.h
  259    26   9  C:\SMS\pduconv.c
  417   126  40  C:\PICC\drivers\string.h
   28     0   0  C:\PICC\drivers\stddef.h
   28     0   0  C:\PICC\drivers\ctype.h
  225   111  25  C:\PICC\drivers\stdlibm.h
   70    16   3  C:\PICC\drivers\memmgmt.c
 2628   568 Total
Page ROM  %  RAM  Functions:
0     56   1   5  strlen
0     54   1   8  create_node
0     20   0   6  update_node
0    130   2   8  insert_node_after
0    114   2   8  remove_node
0     68   1   2  @PRINTF_X_9600_31766_31767
0    278   4  11  traverse
0    316   5  15  malloc
0    110   2   8  free
0    860  13  21  realloc
0    252   4  14  convert_ascii_to_7bit
0    252   4  18  ascii_to_pdu
0     40   1   3  @DIV88
0    644  10  26  main
 Segment   Used  Free
00000-00002     4  0
00004-03CBE  3194  12354
How can i make a less expensive code to use a 16F877 or 16F648? (8K and 4 K).
I post my new code...
MAIN.c
#include <18f242.h>
#device icd=true
#use RS232(BAUD=9600, BITS=8, PARITY=N, XMIT=PIN_C6, RCV=PIN_C7)
int main()
   int i;
   int pdulen;
   unsigned char *pdu;
   char buffer[]="This is a First Test";
   printf("%02X",pdu[i]);
   free(pdu);
pducov.c
#include <string.h>
#include <stdlibm.h>     // Contains malloc() function for CCS
#define VERSION 0.1
#define NPC7    63
#define NPC8    '?'
// Reduced LU table for save ROM usage
    32,         /*    32      space                                   */
static int convert_ascii_to_7bit(char *ascii, char *a7bit[]) {
    int r;
    int w;
    r=0;
    w=0;
            *a7bit[w++]=abs(lookup_ascii8to7[(unsigned char)ascii[r++]]);
        } else {
            *a7bit[w++]=27;
            *a7bit[w++]=lookup_ascii8to7[(unsigned char)ascii[r++]]-256;
    return w;
 *          Use +pdu[] for CCS
int ascii_to_pdu(char *ascii, unsigned char *pdu[]) {
    int r;
    int w;
    char *ascii7bit;
    int  len7bit;
    r=0;
    w=0;
    while (r<len7bit) {
        *pdu[w]=((ascii7bit[r]>>(w%7))&0x7F) | ((ascii7bit[r+1]<<(7-(w%7)))&0xFF);
        if ((w%7)==6) r++;
        r++;
        w++;
    free(ascii7bit);
    return w;
I wait for your cooperation
Thank you
densimitre
PostPosted: Tue May 03, 2005 2:33 pm     Reply with quote
I only have a 16F877 and 16F648....
densimitre
PostPosted: Thu May 05, 2005 11:05 pm     Reply with quote
Hello again
Im having troubles cimpiling this part of main.c
for (i=0; i<pdulen;i++) {
      printf("%02hhx ",pdu[i]);
It says: Print Format (%) invalid...
Above code is for ANSI C...and I dont know how to translate into CCS C..
help me please..
Bye
densimitre
PostPosted: Sat Jun 25, 2005 10:38 pm     Reply with quote
Hi
Im having troubles witth the code....is not working very well...in fact, it does´nt converting into correct format...
Can you give some idea about this...
Thank you
softjad
PostPosted: Sun Dec 16, 2007 1:36 pm     Reply with quote
Someone has an example to work?
