aj.. 1wire me baby
Geust
aj.. 1wire me baby
PostPosted: Sat Apr 30, 2005 3:37 pm     Reply with quote
Hey, I change my code,
but it still doesnt work !
can you take a look on my code :
#include <16f870.h>
#fuses XT,NOWDT,NOLVP
#define SKIP_ROM 0xCC
#define CONVERT_T 0x44
#define READ_SCRATCHPAD 0xBE
#define DQ PIN_C4
//#define Tx_DS1820 PIN_C5
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
// OW_RESET - performs a reset on the one-wire bus and
// returns the presence detect. Reset is 480us, so delay
// value is (480-24)/16 = 28.5 - we use 29. Presence checked
// another 70us later, so delay is (70-24)/16 = 2.875 - we use 3.
unsigned char ow_reset(void)
      unsigned char presence;
      output_low(DQ); //pull DQ line low
      delay_us(480); // leave it low for 480us
      input(DQ); // allow line to return high
      delay_us(70); // wait for presence
      presence = DQ; // get presence signal
      delay_us(424); // wait for end of timeslot
      return(presence); // presence signal returned
}                       // 0=presence, 1 = no part
// READ_BIT - reads a bit from the one-wire bus. The delay
// required for a read is 15us, so the DELAY routine won't work.
// We put our own delay function in this routine in the form of a
// for() loop.
unsigned char read_bit(void)
         unsigned char i;
         output_low(DQ); // pull DQ low to start timeslot
         input(DQ);// then return high
         for (i=0; i<3; i++); // delay 15us from start of timeslot
         return(DQ); // return value of DQ line
// WRITE_BIT - writes a bit to the one-wire bus, passed in bitval.
void write_bit(char bitval)
      if(bitval==1) input(DQ); // return DQ high if write 1
      delay_us(104); // hold value for remainder of timeslot
      input(DQ);
}// Delay provides 16us per loop, plus 24us. Therefore delay(5) = 104us
// READ_BYTE - reads a byte from the one-wire bus.
unsigned char read_byte(void)
      unsigned char i;
      unsigned char value = 0;
      for (i=0;i<8;i++)
      if(read_bit()) value|=0x01<<i; // reads byte in, one byte at a time and then
      // shifts it left
      delay_us(120); // wait for rest of timeslot
      return(value);
// WRITE_BYTE - writes a byte to the one-wire bus.
void write_byte(char val)
      unsigned char i;
      unsigned char temp;
      for (i=0; i<8; i++) // writes byte, one bit at a time
      temp = val>>i; // shifts val right 'i' spaces
      temp &= 0x01; // copy that bit to temp
      write_bit(temp); // write bit in temp into
      delay_us(104);
         char get[10];
         int k;
         char temp_f,temp_c;
            ow_reset();
            write_byte(0xCC); //Skip ROM
            write_byte(0x44); // Start Conversion
            delay_us(104);
            ow_reset();
            write_byte(0xCC); // Skip ROM
            write_byte(0xBE); // Read Scratch Pad
            for (k=0;k<9;k++)
               {  get[k]=read_byte();
            printf("\n ScratchPAD DATA = %X%X%X%X%X\n",get[8],get[7],get[6],get[5],get[4],get[3],get[2],get[1],get[0]);
whats wrong??
Thx
burned
PostPosted: Sun May 01, 2005 9:36 am     Reply with quote
I spent 2 1/2 weeks beating my head on trying to get the 1820 to work.
I tried every code segment on this board -- and there are a lot --'just search the forum and you'll find it" -- yeah, you'll find em - lots of em.
BUT -- I got it working last nite. I finally narrowed it down to : CCS compiler does NOT do accurate timing with delay_us
the problem was not the code but the TIMING.
I added a local segment for us delay from some web site (could have been this one -- I spent so much time searching the web for 'working' code for this -- i lost track of what is from where)
#define   XTAL_FREQ   20MHZ      /* Crystal frequency in MHz */
#define   MHZ   *1000L         /* number of kHz in a MHz */
#define   delayus(x)   { unsigned char _dcnt; \
           _dcnt = (x)*((XTAL_FREQ)/(12MHZ)); \
           while(--_dcnt != 0) \
              continue; }
then I replace all the ccs delay_us with the local function delayus and WHAM the code works -- in fact they all started working when I substituted the delay funciton.
The one I have listed has code to deal with the slower clock speeds (like your 4 mhz ) and I chopped that out -- so this prob won't work for you, but the deal is TIMING ! us timing.
find a us delay function for your clock speed to use instead of the library funciton.
good luck
geust
PostPosted: Sun May 01, 2005 11:58 am     Reply with quote
finally some good news!! Smile
Thx,
but how can I create a function that gives me uSeconds???
I'm just a rookie,sorry..
and I dont know how to creat a uSecond Segment
Please help
PostPosted: Sun May 01, 2005 4:26 pm     Reply with quote
It always helps a lot when you mention the compiler version you are using.... See the thread http://www.ccsinfo.com/forum/viewtopic.php?t=19516 for the description of a delay_us() bug in v3.191 - 3.202, causing delays larger than 153 to fail.
