BUZZER
Joaquim
BUZZER
PostPosted: Thu Apr 28, 2005 7:47 am     Reply with quote
i wanted to know how i could do to switch on a buzzer 2 seconds and then switch it off, every 2 seconds during 1 minute and then after this 1 minute
do the same thing every 30 seconds instead of every 2 second...
I hope this is clear.
during 60s
BUZZER ON
2s
BUZZER OFF
then
every 30 s
BUZZER ON
2s
BUZZER OFF
Many thanks !!
SherpaDoug
PostPosted: Thu Apr 28, 2005 9:11 am     Reply with quote
This sounds like a school homework assignment and you don't know where to start.
1) Find out how to turn an I/O pin on and off using output_high(pin) and related functions.
2) Learn how to wait lengths of time using delay_ms(time).
3) Learn how to loop using while().
4) Use a combination of slow loops to set you buzzer control pin.
That is all there is to it.
Also, look at a few of the example programs that come with the compiler. When you have time it pays to read the manual cover to cover. You will find all sorts of neat stuff.
Joaquim
PostPosted: Thu Apr 28, 2005 9:24 am     Reply with quote
My main problem is to delay in a delay...
I don't know how to do that ....
During 60 s do something every 2 s ...
Could someone help me to write that ?
Joaquim
PostPosted: Thu Apr 28, 2005 9:59 am     Reply with quote
I'll try this way.
Any other suggestion ?
Thank you ! Wink
PostPosted: Thu Apr 28, 2005 12:12 pm     Reply with quote
Use a for() loop to control this. Since you know the total amount
of time that you want your action to occur, and you know the amount
of time for one sequence, just divide the total time by the sequence
time. This gives you the number of loops that you want to do.
In your example:
The buzzer is on for 2 and off for 2 seconds. Total = 4 seconds
for the sequence.
The total time for the action is 60 seconds. Divide 60 by 4, which
gives 15. This is the number of loops that you need.
Then use a for() loop to do this:
#define BUZZER_PIN  PIN_B0
main()
int8 i;
for(i = 0; i < 15; i++)
    output_high(BUZZER_PIN);   // Turn on the buzzer
    delay_ms(2000);                 // Wait for 2 seconds
    output_low(BUZZER_PIN);   // Turn off the buzzer
while(1);   // Don't let PIC fall off the end and go to sleep.
Do you understand the math and the concept here ?
Joaquim
PostPosted: Fri Apr 29, 2005 1:53 am     Reply with quote
Thank you !!!
It is what i wanted !
Many thanks !!! Wink
fuzzy
PostPosted: Thu May 05, 2005 12:43 pm     Reply with quote
I think you better use internal PIC counter... it's more useful and precise.
