Embedding Compiler version
prwatCCS
PostPosted: Wed Apr 27, 2005 4:25 am     Reply with quote
Is there a simple way (like the use of the __DATE__ macro) to automatically embed the version of Compiler used to create a particular build, in the final code.
Peter Willis
Development Director
Howard Eaton Lighting Ltd UK
Humberto
PostPosted: Wed Apr 27, 2005 6:16 am     Reply with quote
From the readme.txt
The built in function getenv() has been added. The syntax is
value = getenv(cstring);
cstring is a constant string with a recognised keyword
as follows:
FUSE_SET:fffff Returns 1 if fuse fffff is enabled
FUSE_VALID:fffff Returns 1 if fuse fffff is valid
INT:iiiii Returns 1 if the interrupt iiiii is valid
ID Returns the device ID (set by #ID)
DEVICE Returns the device name string (like "PIC16C74")
CLOCK Returns the Osc clock value (from a #USE DELAY)
VERSION Returns the compiler version as a float
VERSION_STRING Returns the compiler version as a string
PROGRAM_MEMORY Returns the size of memory for code (in words)
STACK Returns the stack size
DATA_EEPROM Returns the number of bytes of data EERPOM
READ_PROGRAM Returns a 1 if the code memory can be read
PIN:pb Returns a 1 if bit b on port p is on this part
ADC_CHANNELS Returns the number of A/D channels
ADC_RESOULTION Returns the number of bits returned from READ_ADC()
ICD Returns a 1 if this is being compiled for a ICD
SPI Returns a 1 if the device has SPI
USB Returns a 1 if the device has USB
CAN Returns a 1 if the device has CAN
I2C_SLAVE Returns a 1 if the device has I2C slave H/W
I2C_MASTER Returns a 1 if the device has I2C master H/W
PSP Returns a 1 if the device has PSP
COMP Returns a 1 if the device has a comparator
VREF Returns a 1 if the device has a voltage reference
LCD Returns a 1 if the device has direct LCD H/W
UART Returns the number of H/W UARTs
CCPx Returns a 1 if the device has CCP number x
TIMERx Returns a 1 if the device has TIMER number x
Examples:
#IF getenv("VERSION")<3.050
#ERROR Compiler version too old for this program
#ENDIF
Hope this help,
Humberto
