Any probelm here....
Jack// ani
PostPosted: Sun Apr 24, 2005 10:22 pm     Reply with quote
Hi all,
I've written this simple program, please see if this is correct.....
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
int16 value;
setup_port_a(ALL_ANALOG);
set_adc_channel(0);
value=read_adc();
printf("Value is : %x ",value);
Please tell me how to convert the integer value into floating decimal value?
PostPosted: Mon Apr 25, 2005 2:47 am     Reply with quote
First thing, 'value', is a long integer. The printf commad to print a 'long' in hexadecimal, is %Lx, not %x.
Add the line:
#device ADC=10
as the second line in the program (otherwise the ADC will only return an 8bit value), and there is no point in using a 'long' variable...
Then to get a 'float', something like this:-
main() {
   int16 value;
   float volts;
   set_adc_channel(0);
   while(1) {
      value=read_adc();
      printf("Value is : %x /n",value);
      //the actual arithmetic will depend on your Vref etc.
      volts=(float)value*0.0048828125;
      printf("Voltage is : %3.2f/n",volts);
The 'cast' (adding the word 'float' in front of 'value'), is not strictly necessary, since the use of a float multiplier, _should_ cause automatic casting, but it is safer in CCS to be 'explicit' about this.
Jack// ani
PostPosted: Mon Apr 25, 2005 11:29 pm     Reply with quote
Thanks for your helpful reply. Where should I add #device ADC=10, in the source file or header file? When I added this in the first line of the code it shows error "A #device required before this line", and when I replaced it with #device PIC16F877A ADC=10, the error is gone. Also when I place this line on the header file instead on source there is no error! Which one is correct way?
Thanks again
PostPosted: Tue Apr 26, 2005 12:09 am     Reply with quote
If you're using the CCS compiler, you should reading or at least
browsing all the posts in this forum every day. Many of the questions
that you have will asked by others every 2-3 days. For example,
your question about where to place the #device adc=10 statement
was just recently answered in this thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=22646
