asic1984
ADC problem? |
Posted: Mon Apr 25, 2005 3:53 am |
hi
i wanna make an ADC code on pic 18f452, 10 bit analog
int x=read_adc();
the problem is that this int value represent 10 bit digit and i wanna send it with the rs232 which is 8 bit ;
how can i access the ADDRESL,ADDRESH of the analog digital convertion result to send each byte alone in the rs232
thanks for help |
Re: ADC problem? |
Posted: Mon Apr 25, 2005 4:22 am |
asic1984 wrote: | hi
int x=read_adc();
thanks for help |
Firstly, what you post will only get the low 8bits of the value, since an 'int' is an 8bit register.
You need to have #device ADC=10, at the top of your code (immediately after loading the 'processor' include file), and use an int16 to hold the value.
Then with:
int16 x;
x=read_adc();
putc(make8(x,1));
putc(make8(x,0));
Will output the two bytes one after the other. You can reverse the order, by swapping the '1', and the '0' at the end of the make8 instruction.
However you should think moderately 'carefully' about sending this sort of value over the serial (consider sending it in hex instead for example), since any value is possible, and some UART drivers will treat characters like line-feed, carriage-return, and EOS, as having significance. Your receiver will need to ensure the driver is in 'binary' mode, and not applying any such filtering.
asic1984
Posted: Mon Apr 25, 2005 4:45 am |
thanks too much for your reply ,but how can i convert the value that i read to a hex value? |
asic1984
Posted: Mon Apr 25, 2005 4:47 am |
rwyoung
Posted: Mon Apr 25, 2005 7:26 am |
printf(streamname, "%04x", read_adc());
Whoops, yep %04LX would be better. Keeping getting myself confused moving between PIC and PC... And personally I like to see the leading zeros. _________________ Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
Posted: Mon Apr 25, 2005 8:18 am |
You actually need '%4Lx', not '%4x', to treat the value as a 'long'. However given that the top nibble is zero, '%3LX', would send the three significant nibbles.
