How to tell if putc will block?
gustnado
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Sat Apr 23, 2005 11:24 pm     Reply with quote
What is the best way to tell if a call to putc will have to wait? I know I could look at the UART status registers, but is there a better way? I don't want to call anything that will block my program - if it's going to block, I want to run background tasks and then check again.
Thanks in advance.
The best weather is bad weather
PostPosted: Sun Apr 24, 2005 12:16 am     Reply with quote
The best way to answer this question is to write a test program
that uses putc(), and then look at the .LST file to see what the
compiler is doing.
#include <18F452.h>
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
putc(0x55);
Here is the section of the .LST for putc(). You can see that it's
testing bit 4 of register 0xF9E.
0000                00312 ........ putc(0x55);
0020 0E55           00313 MOVLW  55
0022 A89E           00314 BTFSS  F9E.4
0024 EF11 F000      00315 GOTO   0022
0028 6EAD           00316 MOVWF  FAD
0000                00317 ..........
Referring to the data sheet, we can see that 0xF9e is PIR1, and
bit 4 is the TXIF bit. Looking farther in the data sheet, you can
see a description of the TXIF bit in section 8.2.
bit 4 TXIF: USART Transmit Interrupt Flag bit
1 = The USART transmit buffer, TXREG, is empty (cleared when TXREG is written)
0 = The USART transmit buffer is full
So if you don't want putc() to block, you need to test that bit before
you call putc().
#byte PIR1 = 0xF9E
#bit TXIF = PIR1.4
main()
char c;
if(TXIF)
   putc(c);
   // Do something else if the transmitter is not ready
My overall point is that this type of question is best answered by looking
at the .LST file and the data sheet.
gustnado
Re: How to tell if putc will block?
PostPosted: Sun Apr 24, 2005 9:04 am     Reply with quote
Thanks for the code example and technique. I will use it if I don't get a better one (see below). I suspect you have shown the only way to do it.
I was aware I could look at the UART. However, getc() has a routine (kbhit()) that will tell if it will block. I wondered if there were a corresponding C routine for putc, which would provide the same device configuration independence that kbhit() provides.
Again, thanks.
PostPosted: Sun Apr 24, 2005 12:40 pm     Reply with quote
No, there isn't a kbhit-type of function for putc().
All the CCS functions are in listed the manual, or the Help file, or
the README.TXT file. To see if CCS has a certain function that
you want, look at these documents. Here are their locations:
Compiler Manual, revised on Feb. 2005:
http://www.ccsinfo.com/ccscmanual.zip
Help File:
C:\Program Files\Picc\Ccsc.hlp
Readme.txt File. This file has information on new functions:
C:\Program Files\PICC\Readme.txt
gustnado
PostPosted: Sun Apr 24, 2005 1:30 pm     Reply with quote
I read the manual, suspected as much (although it would be easy to miss a function - there are a bunch of them).
Also, setjmp is not in the manual (that I could find - I have the Feb 2005 printed one here) but putc is, indicating that the manual is not complete. Hence I thought it worth asking.
Now we have a definitive answer: there is no kbhit equivalent for putc.
Thanks for the information. I will use assembly language to achieve my non-blocking putc.
jds-pic
PostPosted: Sun Apr 24, 2005 1:41 pm     Reply with quote
on a limited-memory uC there is no such thing.
jds-pic
ps
you can use CCS C to develop an elastic store to mimic a non-blocking putc.
gustnado
PostPosted: Sun Apr 24, 2005 2:26 pm     Reply with quote
I've been doing it for years on a Motorola 68HC705C8 which has less memory than the 18Fxx2 PICs.
I don't mean buffered putc, but rather one which allows other tasks to run while it is waiting for the UART to become free.
Here, the pseudo-code will be:
send_char
while ( putc_will_block )
run_background_tasks
putc
The clever printf in this compiler (which I am really liking) allows me to use this kind of non-blocking putc from the high level (printf). That's quite cool.
Receive buffering is a more important objective, and I thank you for reminding me of the need for it.
