Auto baud detection algoritm
mesuty
PostPosted: Sat Apr 23, 2005 2:20 am     Reply with quote
Hi friends;
Did somebody work before on automatic baudrate detection in PIC 18xxx series of MCUs.
My baudrate range is between 9600-115200 . What is the logic behind the automatic baud rate sensing.
Could somebody give me a light )
Thanks.
Humberto
PostPosted: Sat Apr 23, 2005 8:10 am     Reply with quote
1) Calculating the edges time interval
http://ww1.microchip.com/downloads/en/AppNotes/00962a.pdf
2) Searching for a Bit pattern recognition:
http://www.iol.ie/~ecarroll/autobaud.html
Humberto
Mark
PostPosted: Sat Apr 23, 2005 12:43 pm     Reply with quote
There is also a boot loader for the PIC on Mircochip's website that has an autobaud routine in it.
Humberto
PostPosted: Sat Apr 23, 2005 12:51 pm     Reply with quote
Also if the PIC 18xxx you are using have hardware EUART you can use:
setup_uart(UART_AUTODETECT);
and will sets the UART baud rate to match.
I never use it.
Humberto
Neutone
Re: Auto baud detection algoritm
PostPosted: Tue Apr 26, 2005 3:47 pm     Reply with quote
mesuty wrote:
Hi friends;
Thanks.
I posted an example that uses framing errors to know the baud rate is wrong. Starting at the highest baud rate and reducing the baud rate until the correct baud rate is found.
http://www.ccsinfo.com/forum/viewtopic.php?t=19306
