Bandpass filter
prayami
Bandpass filter
PostPosted: Thu Apr 21, 2005 4:28 pm     Reply with quote
Hi..
We want to make band pass filter to pass 1KHz to 20Khz frequency.
This is to eliminate noise.
Is there any Microchip processor that CCS support have internal band
pass filter. Or we need to make software band pass filter.
How can we make software bandpass filter?
We don't want to use any external hardware IC to reduce cost.
Any advice appreciated....
rwyoung
PostPosted: Thu Apr 21, 2005 4:59 pm     Reply with quote
Just shots in the dark because your post doesn't have enough information to be specific:
No PICs (to my knowledge) have built-in filtering hardware. You will have to do it with code.
You might be able to use a dsPIC and make a bandpass FIR filter. Depending on the number of taps you need you might be able to use an 18F part but probably can't get the 20kHz upper cut-off frequency. The number of taps in the FIR filter will be determined by the passband and stopband parameters which you didn't specify.
In fact for most PICs except some of the newer 18F's if you plan to sample the analog signal with the PIC, you are going to be out of luck sampling faster than 30ksps. There are some PICs that can hit 100ksps.
How cost sensitive is your design? I know you said you didn't want a hardware solution but a dual op-amp and about 5 resistors and 5 capacitors will get you an analog 2nd order bandpass filter. You could also get switched capacitor filter blocks from Linear Tech and Maxim that might do the job.
You can build very nice passive bandpass filters with RLC circuits too.
Rob Young
prayami
PostPosted: Thu Apr 21, 2005 8:04 pm     Reply with quote
Hi..
We want to pass frequency between 1KHz to 20KHz. We want to stop
frequency below1KHz and frequency above 20KHz. Is passband and stopband
parameters are different than this one then please let me know what is that?
Not only cost but we don't want to go for hardware because it reduces
the accuracy.
If we use PIC18, How much upper cutoff frequency we can get?
How exactly we can do it in the software? Is there any coding for that?
If you can then please send some sample coding so that I can get some
idea.
If we have to use dsPIC and make a bandpass FIR filter, How can we do
that in dsPIC? I don't have any indea. Please specify that as well.
Thanks ......
sseidman
PostPosted: Fri Apr 22, 2005 6:24 am     Reply with quote
Hi..
Unless you can sample at approximately 50K, give up on the idea of filtering at 20K. Sampling theory says that any signal present at higher than half your sampling rate will "alias", or disguise itself as a lower frequency.
The right way to deal with noise at frequencies this high is to analog prefilter. Microchip has the design tools on the website for active filters.
Scott
SherpaDoug
PostPosted: Fri Apr 22, 2005 7:43 am     Reply with quote
Even sampling at 50kHz will only allow you to filter out noise up to 30kHz. Noise from 20kHz to 25kHz will be stopped by the filter. Noise from 25kHz to 30kHz will be aliased down to the 20 to 25kHz band and then stopped by the filter. Noise above 30kHz will be aliased down below 20kHz and will go sailing right through!
A cheap simple analog filter is the way to go. What is your "accuracy" requirement? If the low frequency cutoff is 1kHz you clearly don't care about DC offset.
rwyoung
prayami wrote:
Hi..
parameters are different than this one then please let me know what is that?..
Stopband attenuation (upper and lower frequencies)? Passband ripple? Passband attenuation and gain? Sampling frequency, keeping in mind that you need to sample at least 2x the highest frequency you expect to pass but that is the absolute minimum, you would get much better results with 10x to 20x oversampling.
You have a lot of research to do into FIR filters and their design and implementation forms before you can do this and my gut feeling is that a PIC18 running at 40MHz is going to be marginal for this application, if it is even able to perform the function at all.
Rob Young
SherpaDoug
PostPosted: Fri Apr 22, 2005 7:48 am     Reply with quote
rwyoung wrote:
Sampling frequency, keeping in mind that you need to sample at least 2x the highest frequency you expect to PASS but that is the absolute minimum, you would get much better results with 10x to 20x oversampling.
Acutally it is 2x the highest frequency you expect the software filter to STOP. Except that with aliasing you can actually stop a little higher, as long as everything in the system is linear.
rwyoung
PostPosted: Fri Apr 22, 2005 9:15 am     Reply with quote
Yep, fingers got ahead of brain...
Rob Young
