disable interrupts
ariza
disable interrupts
PostPosted: Thu Apr 21, 2005 5:11 pm     Reply with quote
Hi all
In my project I use 18f452 and its three external interrupts with three buttons(using debounce circuit).In ext interrupt routine I enable/disable other two external interrupts. Something like start/stop button.
My all program work in ext1 routine and in ext2 routine I take situation of four pins .I disable these two interrupts with this
#int_EXT
EXT_isr()
 if(a==1)
     a=0;
     disable_interrupts(INT_EXT1);
     disable_interrupts(INT_EXT2);
     a=1;
     enable_interrupts(INT_EXT1);
     enable_interrupts(INT_EXT2);
and other routines
#int_EXT1
EXT1_isr()
    a=1;
   output_high(PIN_C0);      //control led
  delay_ms(20);
    output_low(PIN_C0);
  delay_ms(20);
#int_EXT2
EXT2_isr()
    a=1;
After these two interrupt routines are disabled with pressing RB0 pin, if I press RB1or RB2 button nothing happen. When I enable them with pushing RB0, the interrupt routine which I pushed starts to execute(no pushing again).
So how can I prevent this? If program is executing I want to stop it or if It is not working I want to start it. Can anyone tell me what must I do? I gave priority to these interrupts but it doesn't prevent this situation. I think The reason of this is the interrupt flag. Am I right?
Thanks for your advice
BEST REGARDS
EMRAH
Mark
PostPosted: Thu Apr 21, 2005 7:27 pm     Reply with quote
Yes, it is the flags. You will need to clear them when you enable them. Check the manual or help file for clear_interrupt().
ariza
PostPosted: Fri Apr 22, 2005 5:02 am     Reply with quote
Hi
How can I use clear_interrupt()? because I could not find anything CCS Help. Can you recommend other methods to prevent it?
Thanks for your help
BEST REGARDS
ARIZA
Mark
PostPosted: Fri Apr 22, 2005 6:02 am     Reply with quote
Your version of the compiler might not support it if it is too old. But here it is
CLEAR_INTERRUPT( )
Syntax:
clear_interrupt(level)
Parameters:
level - a constant defined in the devices.h file
Returns:
undefined
Function:
Clears the interrupt flag for the given level. This function is designed for use with a specific interrupt, thus eliminating the GLOBAL level as a possible parameter.
Availability:
All devices
Requires
Nothing
Examples:
clear_interrupt(int_timer1);
Example Files:
None
Also See:
enable_interrupts(), #INT
If you compiler doesn't support it, then just clear the appropriate flag bits in the PIR & INTCON registers. I believe yours are all in the INTCON's but you can read the datasheet to find that out.
No, except don't press the other buttons!
ariza
PostPosted: Sun Apr 24, 2005 9:16 am     Reply with quote
hi all
If I have infinite loop inside Interrupt routine Forexample: an analog to digital conversion (a infinite loop).
#int_TIMER0
TIMER0_isr()
    do {
         for(i=0; i<2; ++i)
                   set_adc_channel(i);
                    delay_us(10);
                    data = read_adc();
                     pc=data;
             }while(TRUE);
//Three channel A/D conversion.
Suppose you define the Timer0 interrupt in another interrupt routine forexample ext1 and give the
#int_EXT
EXT_isr()
   setup_timer_0(RTCC_INTERNAL|8);
   set_timer0(100);
Does it contain any risk or is it possible doing like this?
BEST REGARDS!
Ariza Smile Very Happy
PostPosted: Mon Apr 25, 2005 2:35 am     Reply with quote
Personally, I'd 'reorder' things a little.
Unless you ae using the timer elsewhere, why not leave it programmed to the clock rate you require outside the interrupt. So the 'setup_timer_0' routine, could be in the main. This saves a few instructions in the interrupt handler.
Then set the timer to the required count value, _clear the interrupt flag_, then enable the interrupt. You really need to clear the interrupt flag before enabling the interrupt, since the timer may well have been runnin, and the interrupt therefore may well have triggered, but not been serviced (since the interrupt was disabled).
ariza
PostPosted: Tue Apr 26, 2005 8:04 am     Reply with quote
Hi
I must define Timer0 in ext, in my algoritma ext interrupt routine is the importanat part something like starts and finishes all program.
doesn;'t it reset my program because I do all my work in ext routine.
And when program enters in an interrupt routine, doesn't it disable other interrupts? Am I wrong?
By the
#int_EXT
EXT_isr()
if(x==1)
   setup_timer_0(RTCC_INTERNAL|16);
   set_timer0(100);
   set_timer0(80);
SOmething like this, is it possible ?
When program is executing, does it work?
Thanks...
BEST REGARDS Smile Very Happy
ARIZA
PostPosted: Tue Apr 26, 2005 8:10 am     Reply with quote
When you are in an interrupt handler, the _global_ interrupt flag is dsabled, but the individual interrupts are not. If the individual interrupts were disabled, it would result in data being lost from everything like serial interrupts when you were in another handler...
Timer0, is running all the time. It's interrupt flag _will_ be set, if you have not had it's interrupt enabled. Hence you _must_ clear the interrupt before enabling it. It is not hard, the compiler supports a clear_interrupt instruction now.
