Pointer to union
alexz
Pointer to union
PostPosted: Thu Apr 21, 2005 6:30 am     Reply with quote
I have got the following union:
extern union unionFloat
float fl;
unsigned char cha[4];
How to make a pointer to it and how to use it?
Thank you
Alex
Mark
PostPosted: Thu Apr 21, 2005 7:02 am     Reply with quote
typedef union
  float fl;
}UNION_FLOAT;
extern UNION_FLOAT unionFloat;
extern UNION_FLOAT * ptr_unionFloat;
alexz
PostPosted: Thu Apr 21, 2005 7:06 am     Reply with quote
Right,
and how to use it?
I mean, I want to point to the UNION_FLOAT.fl
Alex
Mark
PostPosted: Thu Apr 21, 2005 7:11 am     Reply with quote
ptr_unionFloat->float = 54.5;
ptr_unionFloat->cha[0] = 1;
ptr_unionFloat->cha[1] = 2;
ptr_unionFloat->cha[2] = 3;
ptr_unionFloat->cha[3] = 4;
alexz
PostPosted: Thu Apr 21, 2005 7:16 am     Reply with quote
I pass the pointer to another function like so: ptr_uFloat->fl
I get the error: Error [1146] type mismatch in argument 2
I need to pass the address of the value in the uFloat.fl
Alex
Mark
and how is the other function declared?
alexz
PostPosted: Thu Apr 21, 2005 7:19 am     Reply with quote
extern void writeSFlash(uchar noBytes, uchar *sfData);
Alex
Mark
PostPosted: Thu Apr 21, 2005 7:22 am     Reply with quote
writeSFlash(sizeof(unionFloat.cha),ptr_unionFloat->cha);
alexz
PostPosted: Thu Apr 21, 2005 7:24 am     Reply with quote
Mark wrote:
writeSFlash(sizeof(ptr_unionFloat->cha),ptr_unionFloat->cha);
Mark, I can't change it, because this function is called a lot and addresses of variables and arrays are passed to it.
Alex
alexz
PostPosted: Thu Apr 21, 2005 7:30 am     Reply with quote
Thank you for the help Mark.
I think I have found the way to do it
writeSFlash(0x04,(unsigned char *)ptr_uFloat);
Alex
Mark
PostPosted: Thu Apr 21, 2005 7:34 am     Reply with quote
You don't need a pointer to the union if you are just trying to pass and address
writeSFlash(4,unionFloat.cha);
writeSFlash(4,&unionFloat.cha[0]);
writeSFlash(4,(uchar*)&unionFloat.fl);
Either of the above would work for you.
alexz
PostPosted: Thu Apr 21, 2005 7:44 am     Reply with quote
Thanks Mark, yes, it is working
Alex
