Program hang--CCS compiler problem?
cindyw
PostPosted: Tue Apr 12, 2005 8:01 pm     Reply with quote
Is it possible for the program run to an non-implemented memory area?
In debug mode, I have encounted this problem.
My device with progammed PIC16F684 run very well. But it hangs somewhere in one test and i can not repeat this problem again.
I am using
CCS PCM C Compiler, Version 3.217, 27214
Appreciate any advise
Confused
CC
Mark
PostPosted: Tue Apr 12, 2005 8:21 pm     Reply with quote
You will need to post code to get help
PostPosted: Tue Apr 12, 2005 8:48 pm     Reply with quote
Here is the main program
#include "D684BB.h"
#DEVICE adc=8
#fuses INTRC_IO,NOPROTECT,WDT //NOWDT
#use delay (clock=4000000)  //4M hz internal osc
#include "DinitialBB.c"
#include "DcommonBB.c"
          Main program
   { int t1=0;
     int t2=0;
     int t3=0;
     delay_ms(200);  // add on 13/4 until stable  ??
//----------------ini-----------------
//----WDT initialization---
        SETUP_WDT(WDT_DIV_65536);
     //----ADC initialization---
      SETUP_ADC_PORTS(sAN4|sAN5|sAN6|sAN7|VSS_VDD);       setup_adc( ADC_CLOCK_INTERNAL );   //internal 2-6us
      SETUP_COMPARATOR(NC_NC_NC_NC);
//----Timer1 initialization---
        SETUP_TIMER_1(T1_INTERNAL|T1_DISABLED|T1_DIV_BY_8);    //prescale=1:8, internal clock
        #asm
        bcf 0x03,0x5  //bank0
        bcf 0x10,0x0 //tmr1on=0, stops timer1
        #endasm
//----Timer0 initialization---
        #asm
        clrwdt   // clr WDT and postscaler
        bsf 0x03,0x5  //bank1
        movlw 0x06  //'00000110'    //prescale=128, internal cloc
        movwf 0x81   //save in option_reg
        bcf 0x0B,0x5  //disable TIM0 intp
        #endasm
 //----I/O initialization---
 // change to asm code due to register not set correctly
      #asm
     bcf  0x03,0x5      //bank 0
     clrf    0x05       //
                  clrf    0x07       //;Init PORTC
     bsf  0x03,0x5       //bank 1
     movlw 0x08
     movwf 0x85       //set TRISA RA0-2,RA4,5  as output
     movlw 0x0f
     movwf 0x87       //set TRISC Rc4,5 as output,other as input
     #endasm
    //init();  // init for ADC, I/O, Timer
     LED_Blink(3,1,30); // indication of MCU working
//--------check Beam connection-------------------------
          set_adc_channel(FBACK);
          delay_us(20);
chk:      t1=read_adc();
         t2=read_receiving(3,10,1);
         delay_us(50);
         t3=read_receiving(3,20,1);
         delay_ms(10);
//based on above reading, find out which beam is connected
           if((t1-t2)<(t1-t3))//(abs(t1-t3)-abs(t1-t2))>5)
             Beam=2;
          else if((t1-t3)<(t1-t2))
               Beam=4;
          if(t1<10)                              Beam=0;
          if(t1>51&&(abs(t2-t3))<5) //2.5V
          Beam=6;
//-----------indication-----------------
          if(Beam==0)
          {LED_Blink2(2,200);
           goto chK;
          Beam=2;    -- for sample only
          switch(Beam){
                           case 2: output_high(LED1);break;
                           case 4: output_high(LED2);break;
                           case 6: output_high(LED2);output_high(LED1); break;
                delay_ms(250);
                 #asm
                   clrwdt
                   #endasm                 delay_ms(250);
                 #asm
                   clrwdt
                   #endasm //; clear watch dog
                delay_ms(250);
                 #asm
                   clrwdt
                 switch(Beam){
                           case 2: output_low(LED1);break;
                           case 4: output_low(LED2);break;
                           case 6: output_low(LED2);output_low(LED1); break;
                             };       //to indicate which beam connected
//-------------checking receiving-----------------------
      if (bit_test(Beam,1))
      ION1=AlignmentCheck(1) ;
      if (bit_test(Beam,2))
      ION2=AlignmentCheck(2) ;
          if(Beam==2)
         NoTarget2=60;           if(Beam==4)
         NoTarget1=60;
         main detection start
//----------enable TIM1 & TIM0 intp---------------
          #asm
          bsf 0x3,0x5  //bank1
          bsf 0x8c,0x0// PIE1.0=1 ,enable timer1 intp
          bcf 0x3,0x5  //bank0
          bcf 0x0c,0x0   // clr overflow flag PIR1.0
          bsf 0x10,0x0 //tmr1on=1, starts timer1
         // clrf 0x0e   //clear TRM1L
          //clrf 0x0f   //clear TRM1H
          bsf 0x0B,0x6//   PEIE of INTCON=1, enable peripheral intp
          bcf 0x0B,0x2//   T0IF of INTCON=1 , clear timer0 overflow flag
          clrf 0x01   // clr TMR0
          bsf 0x0B,0x5//   T0IE of INTCON=1 , enable timer0 intp
          bsf 0x0B,0x7//   GIE of INTCON=1 , enable global intp
          #endasm
       //SETUP_WDT(WDT_ON);   // Start WDT
Chk1:    if (bit_test(Beam,1)==1)
           { CH=10;
             goto process;
Chk2:    if (bit_test(Beam,2)==1)
            CH=20;
process:
           if (done==0)     //done=1 means (TIM1 intp finish)
           goto process;
          done=0;
           if(NoTarget1>=Counter_Notarget && NoTarget2>=Counter_Notarget&&TCont>13&&rlyOn==1)
                   #asm
                   bcf 0x3,0x5  //bank 0
                   bcf 0x5,0x0                     #endasm
                   TCont=0;
                   rlyOn=0;
           if(RCont>100)
             SET_TIMER1(0);
             #asm
             bcf 0x3,0x5  //bank0
             bcf 0x10,0x0 //T1CON-tmr1on=0, stops timer1
             #endasm
             delay_ms(10);
             Read_TRIM();
             RCont=0;
             #asm   //
             bcf 0x3,0x5  //bank0
             bsf 0x10,0x0 //T1CON-tmr1on=1, starts timer1
             #endasm
             if(CH==10)
              goto Chk2;
              goto Chk1;
Mark
PostPosted: Wed Apr 13, 2005 6:30 am     Reply with quote
Well the first thing I look for is to make sure that NOLVP is specified in the fuses. Not all devices have this but I can't tell since you didn't tell us which PIC you are using.
Humberto
PostPosted: Wed Apr 13, 2005 7:16 am     Reply with quote
It is a complex, long and incomplete code that we canīt test. Ovbiously
you come from the assembler arena and your code talk by you, but let
the compiler to do his work, unless you are sure enough of a well know
compiler bug.
You donīt get any advantage toggling the SFR bits by yourself.
Try to post a short code that we can duplicate in bench.
Using goto in C is a non recomended practice, there are nothing
than you canīt do using the C statements.
Humberto
PostPosted: Wed Apr 13, 2005 10:45 am     Reply with quote
Quickly browsing through the 14-pin 16F684 manual I couldn't find an LVP pin, so very likely his problem is somewhere else.
What I don't like in his code is the manual setting of the bank-register. One of the strong points in the CCS compiler is that the compiler takes care of selecting the banks, even when writing assembly. You just declare a variable and have the compiler figure out a free memory location and select the correct bank when required. Changing the banks manually should be possible without problems, but this is not as well tested as other parts of the compiler. So why make life hard on yourself by incorporating instructions the compiler can insert and optimise for you?
I'm not sure what kind of error cindyw is talking about. Probably the compiler would react the way he expects by adding #use FAST_IO
PostPosted: Wed Apr 13, 2005 11:44 am     Reply with quote
"He" is a she.
PostPosted: Wed Apr 13, 2005 3:15 pm     Reply with quote
PCM programmer wrote:
"He" is a she.
Oops. Thanks for correcting me. Embarassed
