monapi Guest
Send / Receive Routine for PIC16F877 |
Posted: Tue Apr 12, 2005 1:57 pm |
I am kinda new to this and im sure that my question is very simple. Could anyone help me in preparing a simple test program that would ensure that my hardware is working.
Basically i would like to transmit a Character 'A', from an output of my PIC to the input pin of a transceiver. The transceiver is a ER400TRS and only implies RS232 data. It does not require any Manchester coding. All this transceiver needs at the input is the basic PICC functions such as getc(), putchar(), and fprintf().
Also how could i then receive this char at the receiving end 250meters away and store in another PIC16F877.
Thank you |
Humberto
Posted: Wed Apr 13, 2005 3:30 pm |
There arenīt any plug & play solution to your inquire.
I will suggest my point of view on how to.
1. I would start playing with 2 PICs, one in each module trying
to gain confidence doing the most trivial task like turning On/Off a LED.
2. Then I would follow sending out a single ASCII chars, while watching with
a scope what is going on the Tx pin. Learnig Start / Stop and Data Bits
3. Then I would connect the Tx Pin of module A to Rx Pin of module B and
would try to catch and store the incoming char in module B.
Once you get running this configuration in a reliable way, then and only then
4. I would try to connect a transceiver to replace the existing wiring link.
Iīm almost sure that to reach step 4 depending on your background you will
need to learn some basic theory and skills that will require spending some days
(weeks ?) reading all the info/papers regarding this matter that you will find out,
googling and asking. Of course getting the right book will help strongly.
May be this answer doesnīt solve your problem, but itīs all I can do by now.
Humberto |
