Interrupt Levels - Saving registers ??
Andreas
PostPosted: Sun Apr 10, 2005 3:11 pm     Reply with quote
Hi All,
After searching the forum I couldnt find a sample of how and which registers I should save when using fast interrupts
Can somebody give me some hints or smaples of how dealing with this ?
best regards
Andreas
PostPosted: Sun Apr 10, 2005 3:27 pm     Reply with quote
which registers I should save when using fast interrupts.
Did you see this thread ?
http://www.ccsinfo.com/forum/viewtopic.php?t=19498
future
PostPosted: Sun Apr 10, 2005 3:46 pm     Reply with quote
Fast interrupts must be coded in a way that no external registers are changed or save/restore everything you change.
Code something then watch the generated asm.
In the other thread, I was having problems with the scratch register 3. I did not see that it was being changed.
Andreas
PostPosted: Mon Apr 11, 2005 12:30 am     Reply with quote
Thank You PCM Programmer,
No I didnt See this topic.
For me I think the search function is not very efficient, when searching for interrupt fast I get hundreds of threads.
Thanks for pointing me there, I will try to understand it now. Also the linkjs within this thread have been very helpful
best regards
Andreas
