Help with SPI code
PicNewboy
Help with SPI code
PostPosted: Fri Apr 08, 2005 5:02 am     Reply with quote
I have a problem with a SPI communication between two Pic18f4525
I try with a simple program,the master is the only pic that can use the serial 232 port,the slave make an operation(e.g a sum) and send back the result to master...How I make wrong?
Master Code:
#include <18f4525.h>
#device adc=10
#fuses H4,NOLVP,NOWDT,PUT,NOBROWNOUT
#use delay(clock=40000000)
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7)
void init_spi(void)
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
return;
int data=0;
init_spi();
printf("SPI test start.\r\n");
delay_ms(1500);
while (1) {
spi_write(data);
if (spi_data_is_in())
data=spi_read();
printf("M:data = %d\r\n", data);
Slave code:
int data=0;
init_spi();
while (1) {
data=spi_read();
spi_write(data+1);
Can anyone help me?Thank you.
PostPosted: Fri Apr 08, 2005 5:26 am     Reply with quote
The slave can never generate clock pulses, so the spi_write on the slave is depending on the master to generate the clock pulses, this can be achieved by either adding an extra spi_write in your master or by calling spi_read in the master with a value to be transmitted.
A nice example was posted a few days ago by Ttelmah: http://www.ccsinfo.com/forum/viewtopic.php?t=22416
