mesuty Guest
PIC18F452 with 40.685 Mhz OSC |
Posted: Thu Apr 07, 2005 12:48 am |
Dear Friends;
In my project , I have a PC communicating 30 PIC 18F452 over a four wire RS 422 circuit. Level converter is 2x Max 485 one for TX and other is RX. Enable PIN of RX circuit is directly connected to logic 0 to keep all devices in listen mode. TX of PICS are controlled with PIN_C1. I am using hardware UASRT with 9600 Baud and OSC frequency of PIC is 40.685 MHZ.
For the trial purposes , just a PC and one PIC are connected to comms. line. The RX and TX lines are terminated with 120 ohms at PIC side.
When I start the circuit , I am receiving many garbage charecters. After a few charecters sent , transmision pausing as stated in delay_ms(400); . So the routine is working.
My Compiler version is 3.221.
Could someone help me ?
My test routine is as follows.
#include <18F452.h>
#device adc=8
#use delay(clock=40685000)
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9,stream=MAINCOMM)
set_tris_D(0x00);
set_tris_E(0x00);
set_tris_C(0b10110000);
output_high(PIN_C1); // TX control pin
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_8_bit);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
setup_timer_2(T2_DIV_BY_1,255,16);
enable_interrupts(INT_TIMER3);
enable_interrupts(INT_RDA);
putC('a');
delay_ms(400);
Posted: Thu Apr 07, 2005 1:19 am |
Your #fuses statement is wrong and possibly your clock source too.
Running at 40MHz is only possible with:
1) A 10MHz crystal and enabling the 4xPLL clock multiplier (replace HS by H4 in the #fuses statement).
or
2) An external clock generator and setting the #fuses statement to EC i.s.o. HS.
Check table 22-4 (page 271) of the PIC18Fxx2 manual.
Another problem in your program is that you are activating a lot of interrupts, but you have no interrupt handlers. So once an interrupt becomes activated it's never cleared and effectively stalls your program. |
mesuty Guest
Posted: Thu Apr 07, 2005 8:25 am |
My CPU is working without any problem with HS mode and 40.685 Mhz OSC. Do you think is there a method to communicate at any baud rate, just for trial purposes.
BR. |
Ttlemah Guest
Posted: Thu Apr 07, 2005 8:47 am |
From what you describe, your problem could be line bias. An undriven differential pair like this, is _not_ warranted to float to a '0' ('1' at the PIC) state. You can get differential driver/receivers, that are warranted to do this, or differential terminators that do this. Alternatively, just use a resistive divider terminator. So (for 100ohm termination, rather than 120ohm), use:
5v ------/\/\/\/------+ line1
1k2 |
/ 120R
1K2 |
0v ------/\/\/\/------+ line2
This gives a perceived impedance for the terminator, of 1/(1/1200+1/120+1/1200) = 100R, and applies 0.24v bias voltage to the differential pair. Do this at both ends of the line, and chose which line goes to the high and low connction, so that the bus idles to the 'break' state at the receive pins, and you may well find it all works.
Texas do a software controllable terminator, that is warranted to do this.
HS, is not the suggested mode to operate with an external oscillator. The amplifier in the chip, is only warranted to work to 25MHz, and driving this with an unused 'output' pin, at 40MHz, will waste power. Switch to using EC mode (or EC_IO), which are the recommended modes with an external oscillator.
Mesuty Guest
Posted: Fri Apr 08, 2005 4:23 am |
Thank to everbody replied;
Everythink seems OK now.
B.R. |
