jamesjl
| typdef, struct and enums in ccsc |
Posted: Thu Apr 07, 2005 6:20 am |
Hi all,
In an attempt to make my code as readable as possible for future maintenance I should like to create some enums, typedef structs and arrays of structs!!!!
Does anyone have an opinion as to how well this will work. It seems to compile OK!
typedef enum PortStatusDef
Unconnected = 0,
NewPortDetected = 1,
Port_A = 2,
CheckStillA = 3,
CandidateLow = 4,
CheckIfCOnnected = 5,
NewPortB = 6,
LocalCheck1 = 7,
LocalCheck2 = 8,
Port_B = 9,
PortBLow = 10,
CSLookingForRemote = 11,
WaitPortALow = 12
typedef struct {
PortStatusDef PortState;
int8 PortNumber;
int8 LastState;
int8 NewState;
int8 time;
int8 NewStateStableTime;
} port;
port PortStatus[24];
void ProcessMessage(int8 msg, int8 thisPort)
switch (PortStatus[thisPort].PortState)
case Unconnected :
// detemine what to do here based on value of msg.
case NewPortDetected :
case Port_A :
default:
I guess I'm asking if creating a typedef enum in an attempt to only use the correct value is a good move?
Thanks in advance.
Jason. |
Posted: Thu Apr 07, 2005 3:24 pm |
Using enums, is a good way of helping to prevent 'silly' accidents with values. Especially dealing with a set of values like this, and a switch statement, I'd say it was a good way to go.
There is a 'caveat', that CCS, can develop some oddities if declarations get too complex, but the current versions seem better in this regard...
Posted: Fri Apr 08, 2005 12:56 am |
Many thanks. Any other thoughts on typedef enum or typedef struct?
Regards. |
jamesjl
Posted: Fri Apr 08, 2005 12:57 am |
Sorry. The post above was from me. Just wasn't logged in.
Jason. |
Posted: Fri Apr 08, 2005 1:18 pm |
| I have a question. Will the "PortStatusDef PortState;" in the struct occupy 8-bits or 4-bits in the structure? |
Mark
Posted: Fri Apr 08, 2005 1:46 pm |
| Anonymous wrote: | | I have a question. Will the "PortStatusDef PortState;" in the struct occupy 8-bits or 4-bits in the structure? |
The enum in this case is an 8 bit number so 8 bits. |
