CCS asm macro
boro
CCS asm macro
PostPosted: Wed Apr 06, 2005 11:00 pm     Reply with quote
Hi all
Please help ? I have asm program and want use it in CCS program.
Asm code have macro definitions as:
JNB macro FADDR,NBIT,ADDR
BTFSS FADDR,NBIT
GOTO ADDR
endm
CCS assembler failure to understand this macro.
I try to predefine :
#define JNB(FADDR,NBIT,ADDR) {#asm
BTFSS FADDR,NBIT
GOTO ADDR
#endasm
but not work.
How predefine macro for work with CCS?
Thank you in advance.
PostPosted: Thu Apr 07, 2005 2:18 am     Reply with quote
Key thing. If you have line breaks in a #define, they must be 'escaped', with a '\' character, or the define will end at the line break. In your example, your #define, will actually be translated as:
Which is not what you want!.
Add the '\' to the end of each line except the last, and see if it works.
boro
SSC asm macro
PostPosted: Thu Apr 07, 2005 5:30 am     Reply with quote
ALL RIGHT!
Thank you Ttelmah! Very Happy
