Seeking HELP for PIC12F683 PWM output
djpark
PostPosted: Mon Mar 21, 2005 10:25 pm     Reply with quote
I thought this is going to be a simple practice, but turned out to be a mistery to me. Can someone point out what is wrong and advice to correct to get the PWM output using PIC12F683? I am using PIN_A2 (CCP1) as led output.
TIA,
-- dj
#include <12F683.h>
#fuses NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, BROWNOUT
#use delay (clock=8000000)
   int8 duty;
   setup_oscillator(OSC_8MHZ);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1, 0x3f, 1);
   setup_ccp1(CCP_PWM);
   set_tris_a(0b11111011);
   while (1)
      for (duty=1; duty<255; duty++)
         set_pwm1_duty(duty);
      for (duty=255; duty>0; duty--)
PostPosted: Tue Mar 22, 2005 12:24 am     Reply with quote
One problem I can see immediately is that you're trying to set
the PWM duty cycle to be longer than the period.
The 12F683, in section 11.3.2, says:
"Note: If the PWM duty cycle value is longer than
the PWM period, the CCP1 pin will not be cleared".
This means the output stays at a high level.
You've set the PWM period to 0x3F here:
But then here, you're setting the PWM duty cycle
to a value greater than 0x3F.
See this post for more info:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729
djpark
PostPosted: Tue Apr 05, 2005 3:25 am     Reply with quote
Thanks for the info. But I think I am missing something very basic.
When I tried the following code, it doesn't turn on the led connected to PIN_A2 at all.
Is there anything else I need to setup to use the PWM?
-- dj
#include <12F683.h>
#fuses NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, NOBROWNOUT, NOIESO, NOFCMEN
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
   setup_timer_2(T2_DIV_BY_16, 124, 1);
   set_pwm1_duty(100);
PostPosted: Tue Apr 05, 2005 8:36 am     Reply with quote
In the link that I posted, there is sample code at the end of the thread.
Look at the last line in that sample program.
Look at the comment on that last line.
djpark
PostPosted: Tue Apr 05, 2005 9:05 am     Reply with quote
Sorry, it was my mistake to omit from the source posted. But it is actually there in my test program as below.
   while (1)
Even then, there is no light coming out of the led from PIN_A2.
I am wodnering if there is something else I need such as enabling timer interrupt or anything else.
-- dj
PostPosted: Tue Apr 05, 2005 11:09 am     Reply with quote
Post your version of the compiler.
I'll compile the program with that version and look at the ASM code.
djpark
PostPosted: Wed Apr 06, 2005 10:46 am     Reply with quote
Thanks for help.
I use PCM 3.187 and it generated the following LST.
#include <12F683.h>
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
   setup_timer_2(T2_DIV_BY_1, 124, 1);
   set_pwm1_duty(100);
   while (1)
CCS PCM C Compiler, Version 3.187, 22755
               Filename: 683-pwm.LST
               ROM used: 74 (4%)
                         Largest free fragment is 1974
               RAM used: 5 (4%) at main() level
                         5 (4%) worst case
               Stack:    0 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
0004:  MOVLW  07
0005:  MOVWF  0A
0006:  CALL   7FF
0007:  BSF    03.5
0008:  MOVWF  10
0009:  MOVLW  00
000A:  MOVWF  0A
000B:  GOTO   00C
....................  #include <12F683.h>
....................  //////// Standard Header file for the PIC12F683 device ////////////////
.................... #device PIC12F683
.................... #list
.................... #fuses NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, NOBROWNOUT, NOIESO, NOFCMEN
.................... #use delay (clock=8000000)
000C:  CLRF   04
000D:  MOVLW  1F
000E:  ANDWF  03,F
000F:  BSF    03.5
0010:  MOVF   1F,W
0011:  ANDLW  F0
0012:  MOVWF  1F
0013:  BCF    03.5
0014:  BCF    1F.6
0015:  MOVLW  07
0016:  MOVWF  1F
0017:  MOVLW  70
0018:  BSF    03.5
0019:  MOVWF  0F
....................    setup_oscillator(OSC_8MHZ);
001A:  MOVLW  70
001B:  MOVWF  0F
....................    setup_adc_ports(NO_ANALOGS);
001C:  MOVF   1F,W
001D:  ANDLW  F0
001E:  MOVWF  1F
001F:  BCF    03.5
0020:  BCF    1F.6
....................    setup_adc(ADC_OFF);
0021:  BSF    03.5
0022:  MOVF   1F,W
0023:  ANDLW  0F
0024:  MOVWF  1F
0025:  BCF    03.5
0026:  MOVF   1F,W
0027:  ANDLW  0C
0028:  MOVWF  1F
....................    setup_comparator(NC_NC);
0029:  MOVLW  07
002A:  MOVWF  19
002B:  BSF    03.5
002C:  MOVF   05,W
002D:  MOVLW  06
002E:  BCF    03.5
002F:  MOVWF  20
0030:  DECFSZ 20,F
0031:  GOTO   030
0032:  NOP
0033:  MOVF   19,W
0034:  BCF    0C.3
....................    setup_vref(FALSE);
0035:  BSF    03.5
0036:  CLRF   19
....................    set_tris_a(0b11111011);
0037:  MOVLW  FB
0038:  TRIS   5
....................    setup_timer_2(T2_DIV_BY_1, 124, 1);
0039:  MOVLW  00
003A:  BCF    03.5
003B:  MOVWF  21
003C:  IORLW  04
003D:  MOVWF  12
003E:  MOVLW  7C
003F:  BSF    03.5
0040:  MOVWF  12
....................    setup_ccp1(CCP_PWM);
0041:  BCF    06.3
0042:  BCF    03.5
0043:  BCF    06.3
0044:  MOVLW  0C
0045:  MOVWF  17
....................    set_pwm1_duty(100);
0046:  MOVLW  64
0047:  MOVWF  15
....................    while (1)
0048:  GOTO   048
0049:  SLEEP
Configuration Fuses:
   Word  1: 30D4   NOWDT NOCPD NOPROTECT NOMCLR NOPUT INTRC_IO NOBROWNOUT NOIESO NOFCMEN
-- dj
DragonPIC
PostPosted: Wed Apr 06, 2005 11:32 am     Reply with quote
Did you check your hardware?
-Matt
PostPosted: Wed Apr 06, 2005 12:36 pm     Reply with quote
Your version of the compiler is buggy with the 12F683.
You will need to make the changes shown in bold below.
Reasons:
Problems with the start-up code:
The compiler is calling address 0x7FF, as if this PIC has an OSCCAL
value at that address. However, it does not, so this is a bug.
Also, the value is being put into the OSCTUNE register, since this
PIC has no OSCCAL register.
The work-around is to use a #rom statement to place a RETLW 0
opcode there. This will cause your version of the compiler to load 0
into the OSCTUNE register, which is the power-up default value.
Doing this will fix the bug.
Problems with setup_ccp1(CCP_PWM):
The compiler is setting up the wrong port and the wrong pin for
the PWM output. By doing output_low(PIN_A2) in standard i/o mode,
we can fix this. The compiler is also using the wrong address for
the CCP1CON register. We can fix this by defining the register address
with a #byte statement, and then writing to it directly with a line of code.
Problems with set_pwm1_duty(100):
The compiler is using the wrong address for the CCPR1L register.
We can fix this by defining the CCPR1L address with a #byte statement
and writing directly to the register with a line of code.
My comment: Your version of the compiler is buggy with this PIC.
Assume that there may be other bugs that you may discover in the
future.
#include <12F683.h>
#ROM 0x7FF = {0x3400} // Add this line
#byte CCPR1L = 0x13
#byte CCP1CON = 0x15
setup_adc(ADC_OFF);
setup_vref(FALSE);
// setup_ccp1(CCP_PWM); // Comment out this line
output_low(PIN_A2); // Add this line
CCP1CON = CCP_PWM;
// Add this line
// set_pwm1_duty(100); // Comment out this line
CCPR1L = 100; // Add this line
djpark
PostPosted: Wed Apr 06, 2005 12:45 pm     Reply with quote
As I read your post, something struck my mind.
I was using a breadboard to test and decided to give a check on the all the pins. Then I found that a few of the holes in the middle where the PIC chip is going doesn't provide the contact. It is surprising to see such wear and tare.
Thanks, PCM for great help for fixing the code.
After replacing with a new breadboard, it works like a magic.
Thanks a lot for everyone's help.
-- dj
