#use rs232
t.gasser
#use rs232
PostPosted: Fri Apr 01, 2005 3:13 pm     Reply with quote
hello
i bought a new version of the compiler. reading the manuel (02.2005) i fount that there is no ENABLE=PIN-Option listed. is this option removed in the this version? if yes, how does it work with a rs485 bus?
thanks for help
thomas
Humberto
PostPosted: Sat Apr 02, 2005 11:17 am     Reply with quote
Hola thomas,
Yes, unfortunately you are right. Confused
I have been reading the readme.txt where CCS inform
the new features that is not in the manual, nothing mention.
The on line version of the manual was not updated since August 2004. Shocked
You can define the use of a dedicated PIC pin as the ENABLE RS485 control as follow:
#use rs232(BAUD=19200, XMIT=PIN_C6, RCV=PIN_C7, ENABLE=PIN_C5, stream=RS485)
Keep well,
Humberto
t.gasser
PostPosted: Sun Apr 03, 2005 11:41 pm     Reply with quote
hello humberto
thanks for help, will try it like that.
have a nice day Smile
thomas
