davt
use of float |
Posted: Thu Mar 31, 2005 4:17 am |
Hi everybody
I am designing a long delay timer and I need a 32 bit variable to count a large number of "ticks" , can I just declare a float variable and use it to count the "ticks" .
Dave |
valemike Guest
Posted: Thu Mar 31, 2005 7:41 am |
I don't know what the range of CCS's floats are, but even those are finite.
How many ticks, or Seconds, do you want to elapse? For example, if I wanted to count, say, 30 minutes, I would do the following.
Looking at CCS's example program ex_stwt1.c, there is a SECONDS timer. So if I wanted to get 30 minutes out of it, then I would need 60 x 30 = 1800 seconds. See how 1800 easily fits inside an "unsigned long" which can go up to 65535 (thus 65535 / 60 = 1092 minutes).
That is how i would go about achieving a long timer, rather than using a float. |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Thu Mar 31, 2005 7:46 am |
So, why not use int32? |
DragonPIC
Posted: Thu Mar 31, 2005 10:58 am |
Darren Rook wrote: | So, why not use int32? |
good question. _________________ -Matt |
