programme memory read
vin
PostPosted: Wed Mar 30, 2005 4:58 am     Reply with quote
when multiple tables are created using TABLE COMMAND all is not working properly. "pcl" register updates are not correct.
PostPosted: Wed Mar 30, 2005 5:23 am     Reply with quote
1) Post once. Posting multiple times to the group with the same qustion, will just annoy people, and make it less likely that you will get a reply.
2) Since there isn't a 'table command', you are not going to get much information on your question as posted. Post a small demo program, that shows the problem, and details of the processor with compiler version...
